1978 - 1996 Big Bronco
Gasoline Smell
Old Oct 8, 2003 | 04:57 PM
ironingqueen's Avatar
ironingqueen
Unhappy Gasoline Smell
GETTING NOWHERE WITH MECHANICS....1995 BRONCO 85,000 MILES- STRONG GASOLINE SMELL. NOBODY CAN DIAGNOSE WHAT THE PROBLEM IS. THE U-HAUL GUY THOUGHT IT WAS A GASKET WHERE YOU PUT THE GAS IN THE TRUCK (SORRY, I'M NOT TECHNICAL). FORD DEALER REPAIRED IT, BUT 2 MONTHS LATER, THE SMELL IS WORSE THAN EVER. WE ARE AFRAID IT WILL BLOW UP IF WE DRIVE IT!
Old Oct 8, 2003 | 06:21 PM
DeGideo's Avatar
DeGideo
I had a similar problem with my 1990 Bronco. It smelled like gasoline for a couple of months. The gasoline smell started getting worse.Two weeks ago, while it was parked for a day, I noticed a small puddle on the ground, on the left rear side of my Bronco. I crawled underneath, and saw where the skid plate covering the fuel tank was wet,and there was gasoline dripping off the left side. The fuel tank had to be replaced. Yours may be just starting to leak, but I'd have it checked. Let it sit for awhile.If you see a small puddle near the rear of your Bronco, then it's the fuel tank. The cost of a replacement tank was $218.97, plus labor to install.
Old Oct 8, 2003 | 06:23 PM
GeoTracker's Avatar
GeoTracker
Does it only smell when the tank is full or all the time? If only when full it might be the fuel pump and the gasket around it at the top of the tank.
Old Oct 8, 2003 | 06:26 PM
greystreak92's Avatar
greystreak92
If you are smelling it while the truck is moving, the leak is most likely in front of you so you may have a leaking injector gasket. Otherwise the filter could have developed a leak at the seam. Any other scenario would most likely yield loss of power and driveablility if it hasn't already. Fuel injection systems require a certain amount of pressure to keep the engine running well. Losing pressure causes all sorts of odd things to happen. The best thing to do is to check along the fuel lines from the tank forward to the engine and fuel rails on the intake for wet spots. And if they "fixed it" just two months ago...I'd be taking it back and demanding that the fix it RIGHT this time. Or calls to the BBB will be in order. Just my opinion.
Old Oct 8, 2003 | 06:35 PM
andym's Avatar
andym
Couple things.
First, please DON'T SHOUT. We can hear you just fine.
Secondly, do you get the smell when the truck isn't running? Is it worse or better when it is running? Have you tried narrowing the leak down? Is it coming from the engine compartment or the fuel tank area?
Are there any modifications on the truck? How does it run other than the leak? Any stumbling, hesitation, etc.?
And welcome to FTE - it's a great resource for Ford truck owners. You'll be an expert in no time.
Old Oct 8, 2003 | 10:42 PM
ironingqueen
(Sorry about the caps, andym!)
Thanks for the info. I can now go to the dealership who did the last "repair" tomorrow armed with questions.
The fuel tank was replaced by the original owners due to water collecting in it (at under 10K miles).
Other than that:
No modifications to the truck.
Runs great, no hesitations, etc. There are no drips of gasoline, only oil. The dealer put it up on the rack and couldn't find any visible leaks. It smells worse when running, although we can't park it in the garage because of the smell. The smell seems to be coming from the back, but with the air on or windows down, it's hard to determine where it's coming from. Smell is worse when the tank is above 1/2 full.
Old Oct 8, 2003 | 10:49 PM
stepman's Avatar
stepman
Also look at the filler vent. Seen these crack up ( on ford more than any other make). Fuel vapors are strong and sometimes hard to pinpoint.
Old Oct 10, 2003 | 09:26 PM
ironingqueen
Thanks, everyone for the great information. The problem turned out to be the gasket (or lack thereof) at the top of the fuel tank. Too bad it's taken a year to solve, but thanks to all the good info you all sent, I was able to go to the service department with a list of what all I wanted them to check.
rneithammer
13
Jan 3, 2015 10:54 PM
playoutside
Sep 9, 2014 02:54 PM
Eicca
Jul 18, 2011 01:12 PM
guindian28
Jan 22, 2011 09:30 PM
61fordf25
Oct 15, 2010 03:55 PM
