My truck has a hard start when cold. Will fire once then dies then cranks for awhile then starts. Smokes when first starting. Runs rough until warms up. Oil pressure drops the gauge at idle comes back when you press the throttle. Ipr was just replaced. Just out stage one turbo in. Full egr delete all the blue springs have been done 6.4 banjo bolts. Hpop is healthy 647lbs at idle about 900's when on throttle. Ficm reads 52 what could cause my issues.
Reading codes with a snap on computer no codes no lights on dash besides when oil pressure drops has a loss of power if I put it to the floor it's doggy just rolls coal
Well the oil pressure dropping is something I would be concerned about by itself. Post some readings and me or someone else on this site will have a better idea what's up.
Ficm, L, M, V.
Icp
Ipr
ECT.
Stage 1 turbo turbo aro headstuds cold air intake original oil cap it's getting oil inside already did that test it has got me and a couple other people stumped wondering if it's injectors
Couple things. One is you need to get the wire harness off the turbo. That turbo gets smoking hot and will melt that harness. You will have all kind of electrical issues if that happens. Pin it up with zip ties if need be.
2 your ipr reading is high if that's at idle. You should be in the 24 to 25 range at idle. That means your system is working hard to keep up pressure. 900 psi is not good eather when your on a hard excel.should be way higher.
Bismic will have some more info on this. The oil cap is one witch is good.
It was 900's not on a hard Excell it was idling in the shop and just pushing the pedal got it to there not sure what it's at when a hard excel wiring was dropped today needs reziptied so. Question could a plugged oil cooler from sluggy oil cause all this truck sat for 2 years. And could my ipr be bad again. Started really well had little problems when I first put ipr in then went bad and right back to where we are when I started this
