Hard start when cold
Old Sep 30, 2019 | 06:47 PM
Farm kid 101's Avatar
Farm kid 101
Oriellys lifetime warranty and I had it sent in and redone
Old Sep 30, 2019 | 06:55 PM
Visurveyor's Avatar
Visurveyor
Where did you send it and what did they redo. If it's an O'Reilly's should be stock. Should run 47.5 to 48.5 average. I'Ve herd of modified ones reading 52.
Old Sep 30, 2019 | 07:20 PM
Farm kid 101
My ipr was bout at oriellys my ficm runs 52 I sent it out
Old Sep 30, 2019 | 09:11 PM
xcrsp440's Avatar
xcrsp440
Word of advice. Never trust aftermarket electrical sensors, OEM is the only reliable source. eBay OEM used is better than oreilly new.
Old Oct 1, 2019 | 02:59 PM
Farm kid 101
Put a monitor on my truck I have a sct x4 my oil temp was 248.60 my coolant temp was 202
Old Oct 1, 2019 | 04:16 PM
Visurveyor's Avatar
Visurveyor
There's an oil cooler replacement in your future. OEM coolers are best . don't bye the cheepos on Amazon or you will be doing again in near future.
Flush your motor really well before you replace your cooler. There are good Diesel Tech Ron videos on both flush and cooler replacement.
Old Oct 1, 2019 | 04:18 PM
Farm kid 101
Coolers I have done one oil flush I have not yet wondering if this could be my entire problem?
Old Oct 1, 2019 | 06:38 PM
xcrsp440's Avatar
xcrsp440
Have you checked if there are any DTCs stored in the computer?
Old Oct 1, 2019 | 06:40 PM
Farm kid 101
I did not see any dtc at all. Also I called my local Ford dealership they said oem oil coolers are opsolette any idea of next best oil cooler kit
Old Oct 1, 2019 | 07:01 PM
bismic's Avatar
bismic
The assembled Oil Cooler Housing and internals is obsolete.
The upgraded core is available everywhere. That is what you want. The part # is 3C3Z-6A642-CA.
Your temperature differential is quite high. Assuming oil and coolant temperatures are essentially the same on a totally cold engine, then installing the updated oil cooler core is a high priority.
Also, the SCT is not a good code reader at all.
Old Oct 5, 2019 | 10:39 PM
Fuzzpuss's Avatar
Fuzzpuss
With an engine bay that looks like that, I can't imagine the truck is having problems. Or am I just being a snob? Really though, that poor truck looks like it's been rode hard and put up wet.
Anyway, what year is the truck? I'm not sure about the newer years, but the 03's and early 04's stock banjo bolts have built-in check valves to maintain fuel pressure in the rails. I bought the 6.4 banjo bolts and never installed them after reading about it. I've been considering replacing the stockers just for the purpose of preventative maintenance.
You say your HPOP is 647 at idle. I just tested mine and its 860 at idle after a cold start and drops down to 750ish after running for a few minutes. Maybe the difference is due to my Dieselsite HPOP. I'm sure Mark will chime in on that one way or another.
If your problem was to do with high oil temps it would be a hot start problem and not a cold start problem, but you will have hot start/run problems very soon if you don't replace that oil cooler.
Old Oct 5, 2019 | 10:45 PM
Fuzzpuss's Avatar
Fuzzpuss
Generally speaking, I agree, but it isn't always gospel. I had two new Motorcraft oil pressure sensors (low pressure) go bad in a matter of months. Replaced with Autozone part with a lifetime warranty and haven't had a problem in three years.
Old Oct 7, 2019 | 07:14 AM
  #28
Farm kid 101
Engine bay looks the way it does bc this truck works it's *** off on a farm for the last 6 years everyday.
Old Oct 7, 2019 | 02:33 PM
  #29
spoolmonster's Avatar
spoolmonster
looks like my engine,i guess when you actually use your truck it gets a little dirty.
Old Oct 7, 2019 | 09:16 PM
  #30
Fuzzpuss's Avatar
Fuzzpuss
Obviously the truck works hard. Your picture told us that. Do you know what else your picture told us? That it hasn't been very well maintained. The fact that you didn't bother to replace the molded plastic wire harness support to keep it off the turbo is confirmation. If you want help diagnosing your hard starts, maybe you should give us more information instead of getting your undies in a bunch over a well-deserved poke in the ribs.
The suggestion that your engine bay is that way because the truck works hard is ludicrous. There are plenty of hard-working trucks around here that don't look like WW3 took place under their hoods.
