First-time Torque Pro User Questions
I have NO Codes and the truck runs great except for yet unexplained engine noises, I have another post about that.
I'm just playing around with the app
Now some questions you experts maybe able to help me with or point me to the proper forum.
1) In Mode 06$ test I get the following "failed" items
MID:$03 TID:$81
- O2 Bank 1 Sensor 3
Max: 3A Min: 0.23A
Test result value: 0A
FAIL
MID:$07 TID:$81
- O2 Bank 2 Sensor 3
Max: 3A Min: 0.23A
FAIL
Is this because there is no 3rd O2 senser on each bank?
2) Also, I don't know what to make of these
MID:$3a TID:$80
- EVAP Monitor (cap off)
Test incomplete or dependant test failed
MID:$3a TID:$81
MID:$3a TID:$82
MID:$3b TID:$80
- EVAP Monitor (0.090")
Max: 859.25Pa Min: -8,192Pa
Test result value: 104.75Pa
PASS
MID:$3c TID:$80
- EVAP Monitor (0.040")
3) And lastly, at least for today.
What's up with the VCT2ERRT value? I was just sitting in the driveway idling.
Thank you
MID:$03 TID:$81
Max: 3A Min: 0.23A
FAIL
MID:$07 TID:$81
Max: 3A Min: 0.23A
FAIL
MID:$3a TID:$80
MID:$3a TID:$81
MID:$3a TID:$82
MID:$3b TID:$80
PASS
MID:$3c TID:$80
Perhaps the most important thing to say about ANY Mode $06 Report is: Mode $06 Diagnostic Tests are a just a series of "SNAPSHOT" readings at the time requested! Completely un-synchronized with the system being tested or reported upon. SO, one must view the readings with this AND current conditions/situations in mind. Example, a Mode 6 test result on upstream O2 Sensors -----??---- when they constantly swing between .1 volts to .9 volts. The Mode 06 current reading depends on when you hit the enter key. HOWEVER, a reading of Zero, or 40 volts would obviously be better than crawling under your truck to get to the damn Bank1 O2 sensors with your multimeter !!!. Similarily - if you run the test within 30 seconds of COLD startup, can't expect sensible readings concerning Catalytic Converters. OR right after Clearing Codes - obviously some systems that require multiple drive cycles to complete will not be ready.
The Monitor Tests (MID) an Test ID (TID) are coded. Best source for the coding information is the OBDII Theory of Operaton Manual for your truck, available FOR FREE from here: https://www.motorcraftservice.com/freeresources/obd . Specify Country and Language then > Free Resources and choose OBDII THEORY OF OPERATION, and select your vehicle.
The page snippit below contains the descriptions for my 2004 5.4L (probably same for yours). Some Monitor tests will NOT run until another has successfully completed. And from that I can tell you have not completed a drive cycle since codes were cleared (one of the reasons I advocate discretion before clearing codes freequently - since it is so easy with Torque Pro). The Mode $06 Monitor reports are common to MANY vehicle types, so the Report contains the Manufacturer's upper and lower limits for determining Pass/Fail so the system can work on 4, 6, 8 cylinder with all sorts of different configurations. But the scanner saw Zero InH2o result - and knew the monitor had never ran even once. Having said that, the EVAP monitor is the hardest one to get to complete. Ie: Speed has to be > 40mph, IAT must be between 40 & 90 degrees, Fuel level > 15% & < 75% an slosh test pass -- etc etc. So do not panic about the listed report items if you have NO DTC relating to it.
If you have not ran across this dashboard, you might find it interesting / usefull.
https://www.f150forum.com/f4/how-use...5/#post6188878
WHY?. I observed that when the PCM changes REQUESTED RETARD - it's like it takes a brief second for CAMs to get into the commanded retard or advance position. During that instant, CAM ERROR will 'bounce' either positive when moving to retard, or negative when moving back to NO RETARD or base timing. I theorized that if the cams responded to advance / retard commands equally - the NET result of that accumulation would be ZERO. Therefore, if NOT, it would indicate direction CAMS are lacking in response performance. This provides one additional tid-bit of diagnostics data. Before my timing job, my truck would accumulate LARGE negative numbers, more on bank 1. Post timing job, mine will grow both directions pretty much equally above and below zero - most times never exceeding + or - 100 to 150 over a 35 mile drive cycle. NOTE the specific value has no real sugnificance - just that the sum total should be around zero.
In your case: At idle in the drive way, the PCM should be requesting _NO_ retard and the CAMS should be locked at BASE timing - thus CAM ERROR should be ZERO. I know - HAVE WITNESSED) the PCM attempting to 'SHOCK' VCT solenoids if abnormal readings exceed some norms. Other than that, I have no explination for your slight posiive RCAM while RPMs are < 800 and Load is < 25%. But the growing negative CAM ERROR TOTAL would indicate that cam is retarded a little (each Torque update cycle is accumulating a negative number into the Accumulator) without seeing any offsetting positive numbers.
WHY?? Sticky VCT solenoid not closing off ALL the way. Chain Stretch that cannot be overcome by Tensioner Arms. Weak Phaser? May not be a serious problem. (Timming DTC's require CAM ERROR greater than 5 degrees for greater than 5 seconds to trip). Just watch things for a while.
I have added your EVAP.csv file for future reference.
Lastly about the cam error, I plan on doing a complete timing job anyway, so I will definitely keep an eye on it and report back
I well remember wondering WHY my truck would decide to 'disable' VCTENA during a drive cycle and stop even trying RCAM. Part of the reason I came up with the VCT ERROR accumulator was trying to establish some parameter under which the PCM software would decide to 'give up' on variable timing. (Never made a connection). But I did surmise that it was a useful indicator - even if it had no OBDII significance other than telling me the cams spent MORE time in the over-retarded or over-advanced state.
I also think if timing chains are worn and stretched to the point ghat the tensioners can no longer remove all the slack - (or actually if they ARE removing all the slack, but can remove NO MORE), I believe that actually results in the cams being "SLIGHTLY" retarded even if the Phasers are locked in the base Zero Retard Position. As both of you stated, at idle mine use to sit there and 'tick' the CAM ERROR up in the negative direction. Even though it ran generally OK except for rough idle and occassional stalling, and misfire troubles, and VCTENA would go false every drive cycle.
Cheers my friend. With wished for a long successful run on your timing job. I'm at ~40k and running beautifully.
As far as the VCT1/2ERR readings go..
is it safe to say that this number is in some way indicative of overall engine health?...in respect to the timing/VCT system?
In my mind the number represents the difference between what is needed and what is given, as far as cam advance and retard goes.
So if both sides are responding similarly to each other, wouldn't that be ideal?
And a number that is small relative to the time the engine is under load is a good thing, right?
Im trying to read the writing on the wall...
I did run a change of 20w50 in mine before my timing job. I saw a 'noticable' difference in the amount of 'SPIKE" in CAM ERROR readings. I surmised the small passageways would not pass enough oil fill retard/advance chambers in the phasers fast enough. Wasn't enough to trigger a DTC (which requires > 5 degrees for > 5 seconds according to specs). But now (post timing job), I'm running 5w30 and get warm fuzzy feeling in seeing ZERO cam error on both banks the majority of the time. And, I love to see the VCTDC on both banks run within one tenth to 4 or 5 tenths of a percent of each other!!!! That suggests to me cam and valve train drag on both banks has to be damn balanced.
And yes, those screenshots are due to a bit of hill climbing yesterday. We live west of Denver in the foothills at an elevation of 5672' and we drove over Guanella Pass which is at 11,706'.
Love it! Had to look that one up!
