Torque App O2 Test
Mode $06 report generated by Torque for Android
==============================<wbr>=============== ===
Vehicle VIN: ----------------------
Vehicle Manufacturer: Ford
Vehicle Calibration ID: ------------
Test report:
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 7.99527V Min: 0V
Test result value: 0.44994V
PASS
MID:$01 TID:$80
Max: 7.99527V Min: 0.45994V
Test result value: 0.72029V
PASS
MID:$01 TID:$81
Max: 3A Min: 0.23A
Test result value: 0.473A
PASS
MID:$02 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
PASS
MID:$02 TID:$81
Max: 3A Min: 0.23A
Test result value: 0.495A
PASS
MID:$05 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$80
Test result value: 0.70309V
PASS
MID:$05 TID:$81
Max: 3A Min: 0.23A
Test result value: 0.469A
PASS
MID:$06 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$81
Max: 3A Min: 0.23A
PASS
MID:$21 TID:$80
- Catalyst Monitor Bank 1
Max: 0.49999Ratio Min: 0Ratio
Test result value: 0.04297Ratio
PASS
MID:$22 TID:$80
- Catalyst Monitor Bank 2
Test result value: 0.05078Ratio
PASS
MID:$30 TID:$eb
Max: -81.63% Min: 225.44%
Test result value: -0.16%
FAIL
MID:$3a TID:$80
- EVAP Monitor (cap off)
Test incomplete or dependant test failed
MID:$3a TID:$81
MID:$3a TID:$82
MID:$3b TID:$80
- EVAP Monitor (0.090")
Max: 779.75Pa Min: -8,192Pa
Test result value: 102.75Pa
PASS
MID:$50 TID:$0e
- O2 Heater Monitor Bank 4 - Sensor 4
Max: 0 Min: 0
Test result value: 48,000
FAIL
MID:$90 TID:$0e
Max: 0 Min: 0
FAIL
MID:$a1 TID:$80
- Misfire Monitor General Data
Max: 24.49993% Min: 0%
Test result value: 0%
PASS
MID:$a1 TID:$81
Max: 0.99953% Min: 0%
PASS
MID:$a1 TID:$82
Test result value: 0.74927%
PASS
MID:$a1 TID:$83
PASS
MID:$a1 TID:$84
Max: 966.60004°C Min: 0°C
Test result value: 597.29999°C
PASS
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535 Min: 0
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
Max: 65,535 Min: 0
PASS
MID:$a2 TID:$80
PASS
MID:$a2 TID:$81
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
Max: 65,535 Min: 0
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
Max: 65,535 Min: 0
PASS
MID:$a3 TID:$80
PASS
MID:$a3 TID:$81
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
Max: 65,535 Min: 0
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Max: 65,535 Min: 0
PASS
MID:$a4 TID:$80
PASS
MID:$a4 TID:$81
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
Max: 65,535 Min: 0
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
Max: 65,535 Min: 0
Test result value: 2
PASS
MID:$a5 TID:$80
PASS
MID:$a5 TID:$81
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
Max: 65,535 Min: 0
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
Max: 65,535 Min: 0
PASS
MID:$a6 TID:$80
PASS
MID:$a6 TID:$81
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
Max: 65,535 Min: 0
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
Max: 65,535 Min: 0
PASS
MID:$a7 TID:$80
PASS
MID:$a7 TID:$81
PASS
MID:$a8 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 7 Data
Max: 65,535 Min: 0
PASS
MID:$a8 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 7 Data
Max: 65,535 Min: 0
PASS
MID:$a8 TID:$80
PASS
MID:$a8 TID:$81
PASS
MID:$a9 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 8 Data
Max: 65,535 Min: 0
PASS
MID:$a9 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 8 Data
Max: 65,535 Min: 0
PASS
MID:$a9 TID:$80
PASS
MID:$a9 TID:$81
PASS
End of report.
