What should 8RT Engine temperatures read using a infrared
Old Sep 27, 2019 | 12:56 PM
50trucking's Avatar
50trucking
What should temperatures read using an infrared in various places on the motor, thermostat housing, radiator top and bottom, etc? Also does the drivers side run hotter than the passenger side?
mine is all over the place.
Old Sep 27, 2019 | 01:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I took these readings on a 95-deg day, after a hard workout (climbing a hill and then sitting in heavy traffic). 160-deg thermostats, 4-row radiator, fan with shroud. Can't really explain why the center of the head would be hotter than the thermostat housing?
Location
Top tank ....................173-179
DS head (center).............183
PS head (center)..............183
DS thermostat housing .....173
PS thermostat housing.......179
Old Sep 27, 2019 | 01:15 PM
52 Merc's Avatar
52 Merc
Just a theory off the top of my head, center of the head is right over the siamese exhaust crossover, so it would be the hottest part of the engine. You may not be measuring water temperature, but iron temperature. Water flowing by would be carrying heat away, but not sitting in one place long enough to reach that temp.
JGreen236
Apr 14, 2020 07:52 AM
acl9865
Mar 11, 2017 02:06 PM
Eric Kropp
Jun 25, 2016 08:32 AM
blueball ranger
1983 - 2012 Ranger & B-Series
Dec 5, 2005 07:11 PM
GregR
Oct 11, 2000 12:33 AM
