4r100 Transmission compatibility
Old Sep 27, 2019 | 10:09 AM
FyreRayne's Avatar
FyreRayne
I have a 1999 Ford E350 super duty 6.8l V10 that needs a transmission and its been hard to find the right one. I have been searching all over EBay and auto wrecking yards to find one. Is it possible to use a F series 4r100 from a 1999 F250 super duty with the same size motor? It’s all the same with being a 4x2 year and motor size.
Old Sep 27, 2019 | 12:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes. Those transmissions are identical.
There is one possible complication. The F-Series had an early and late 1999 model year. I don't think the E-Series did that. The way to make sure you get on that works is to check the sensors on top of the transmission. As long as both have two sensors or both have one sensor you'll be fine.
Old Sep 28, 2019 | 01:32 PM
FyreRayne's Avatar
FyreRayne
What I have found after looking into it more is the tail shaft has a VSS senor that looks like it came from a E4OD that sits on the drivers side of the tail shaft. There is a plug that has been covered up on the top.
Here are some photos that might help. With all the research I am at a loss on what is going on here. The transmission identification states it was built in March of 1999. And I thought the E4OD stopped production in 1997 then was transfer to the 4R100.
Old Sep 28, 2019 | 02:53 PM
Mark Kovalsky
Take that sensor out of the tailshaft and see if there is a gear on the end. If there is, an F-Series trans won't work.
fordmantpw
Jan 17, 2016 06:36 PM
artcat99zl
Modular V10 (6.8l)
Nov 18, 2014 04:44 PM
b574
Dec 28, 2008 07:11 AM
Jackflack
Apr 4, 2004 04:15 PM
