Drum brakes
Old Sep 26, 2019 | 09:57 PM
Bg 7 Fo's Avatar
Bg 7 Fo
Drum brakes
Looking to replace both rear drum brakes on a 74 f250 2wd, does anyone have any recommendations for an entire kit or should I get everything separate, any help would be appreciated
Old Sep 26, 2019 | 10:42 PM
440 sixpack's Avatar
440 sixpack
I'm not aware of any kits , just get what you need at your local parts house.
I always turn good drums and rotors I see no need to replace them if they will clean up good. keep in mind the more expensive longer last pads and shoes usually don't perform as well , I prefer the standard ones. don't kit your wheel cylinders replace them.
Old Sep 27, 2019 | 01:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Bg 7 Fo
Looking to replace both rear drum brakes on a 74 F250 2WD: Does anyone have any recommendations for an entire kit or should I get everything separate, any help would be appreciated.
1973/75 F250 2WD: TWO different brake drums, because...there are TWO different sizes of brake shoes.
12 1/8" x 2" or 12" x 2 1/2" // The brake retracting and hold down springs, brake adjuster and parking brake link springs, self adjuster parts are specific to one or the other.
The wheel cylinders and the wheel cylinder kits are also specific to one or the other.
Old Sep 28, 2019 | 08:17 AM
Ozzie H.'s Avatar
Ozzie H.
As Bill said, be sure you're buying for the correct size brakes. Measure the shoe width. RockAuto.com has "plenty" of brake components for our trucks at good prices. Use their discount code to get another 5% off.
Bronc1
General Automotive Discussion
17
Jul 19, 2012 11:21 AM
mechanicsburg
Nov 9, 2004 05:33 AM
