Map Sensor testing low power
Old Sep 26, 2019 | 03:50 PM
RigCity's Avatar
RigCity
I had been getting low power for sometime and visually confirmed a blowout in the plenum. Yesterday I installed the RRbillet for an instant performance boost. The truck smokes a fraction of what it It used to (edge 80 tune) and there is a significant performance increase. I was under the impression thanks to the leak the engine was not being told the boost pressure it should be so the engine was not commanding what it was programmed to fuel wise in stock or other tunes. I feel if I never drove a 7.3 I would think everything is OK but things could be a little bit faster and show a little bit more pep.
Turbo system parts replaced in the last 18 months
-all boots
-all v band and boot clamps
-bellowed uppipes
-wastegate solenoid
-wastegate vacuum lines
-plenums
-turbo cartridge
-y assembly
-Aih delete
-Ebpv delete
tomorrow’s replacement will be the tube going from the spider to map sensor the current tube is severely degraded. I picked up some USCG A1-15 today but the boat is a better place to make this post than the truck at this time.
After that the only other part in the turbo system left is the map sensor I believe. Fuel filter has 5 k on it and does look black after 10 k my posts on that people have said keep running it. I think it could be o rings but the truck does not show any sign they are bad besides the filter, barely uses oil, and starts immediately. Maybe there’s is a leak but I do not feel replacing them( glow plugs, valve cover gasket, under valve cover harness, o rings, and new bolts) will make the difference I’m looking for. Which brings me to the Map sensor.
Old Sep 28, 2019 | 09:16 AM
RigCity's Avatar
RigCity
I installed the new hose today to the MAP there was some improvement. There were no holes in the old one yet it was brittle and possibly not making a complete seal.
Old Sep 29, 2019 | 10:42 AM
'88 E-350's Avatar
'88 E-350
I assume you have a question about something but don't see one.
Robert6401
Nov 18, 2021 03:53 PM
Markus Luukko
54
Sep 9, 2019 01:43 PM
Shane Wyatt
6.4L Power Stroke Diesel
Jan 19, 2017 09:42 PM
dmonell
Nov 23, 2013 10:58 AM
JTQ0919
Jan 15, 2013 01:56 PM
