Brakes pulled to the floor when engine started?
Old Sep 26, 2019 | 07:33 AM
notyettoday's Avatar
notyettoday
Hey everyone, long time no see!
I just bought a 73 F100 XLT Ranger, and when the engine is started the brake pedal is pulled to the floor by the booster, which I think is contributing to the brakes sticking. is my booster a goner or is there anything I can do to save it?
Old Sep 26, 2019 | 02:05 PM
buckin69bronco's Avatar
buckin69bronco
Does the peddle come back up after a while or do you have to pull it up?
Its most likely the booster (or the internal booster spring) but could be your master cylinder.
might want to try it all with the vacuum line to the booster plugged off/disconnected
Old Sep 26, 2019 | 05:24 PM
notyettoday
Thanks for the reply! everything works fine with the engine off, so I assume disconnecting the vacuum source would produce the same results. Is the spring prone to rusting and falling apart? Guess I'm going to be looking for a new booster. i see 2 different styles in the catalogs
Old Sep 26, 2019 | 07:10 PM
buckin69bronco
Per all the other threads on boosters I think your best or only option is going to be to pull yours and send it off to be rebuilt.
I don’t know if the spring is prone to rusting or breaking.
Old Sep 26, 2019 | 09:04 PM
notyettoday
That's what I was afraid of. I was hoping I was missing something stupid. Thanks for the response, time to find a rebuilder.
HillBillyBuddha
1983 - 2012 Ranger & B-Series
Aug 8, 2018 01:01 PM
Mike1
Oct 11, 2016 07:53 AM
carchub
May 15, 2015 12:30 PM
frogkid11
Oct 30, 2012 10:53 PM
AaronW
Jun 15, 2001 02:15 PM
