Steering stuck in position while turning
Old Sep 25, 2019 | 10:14 PM
brycemay907's Avatar
brycemay907
Hey guys so I just bought a 1995 f-350 with a 5.8l and the power steering is whining. I'm going to replace that, but I don't think thats going to fix my problem. I can be sitting in park and it turns just fine each way, but when I get going, I can turn each way and it'll just stick to that position and not go back center. What do you guys think it could be, and have any of you had the same issue?
Old Sep 25, 2019 | 11:35 PM
timbersteel's Avatar
timbersteel
It could be someone has messed with the steering sector on the steering box and has adjusted it that it is causing the steering to bind up.
Jack the front end up and see if there is anything binding while turning the steering wheel back and forth.
It could be that it's the power steering pump failing and that whining you hear from it.
Old Sep 26, 2019 | 03:25 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Ford power steering pumps aren’t exactly quiet to begin with and then you put additional stress on it with bad ball joints, bad steering gear or something else binding up and it will scream. Find the cause for the steering not returning to center and the pump might whine less.
I my case the ball ball joints were so stiff that it wouldn’t return when driving. I had to steer in the opposite direction to get back to center.
Old Sep 26, 2019 | 03:37 AM
Laggy's Avatar
Laggy
It's either the steering gear (aka steering box) being worn/out of adjustment..or caster, which would only be affected with a really big lift and an adjustment to point the pinion at the now higher transfer case. You do this to avoid driveline vibrations. You can test this by putting an angle finder on top of the ball joint or knuckle, any flat spot will do. Anything below 5-7 degrees would explain it. This scenario is highly unlikely.
My guess is steering box. My 95 F-350 would go down the road and steering wheel would go 1/4 turn left through 1/4 right of center and vehicle would not move from center. I'd be driving with the center steering wheel cocked up and down.
I did a reman box from O'Reilly, but for the money, I should have gone Redhead steering gear for another $100. I have one in my Wrangler and it's going strong after 7 years. Timbersteel could be right in that someone tightened something that you really only tighten as a last resort until you can get a new box. Unless you're into rebuilding steering boxes...
Old Sep 27, 2019 | 10:23 AM
dixie460's Avatar
dixie460
Yeah, likely a failing steering gearbox. Replace it and if your pump is still noisy after that, replace the fluid with Type F transmission fluid. Supposed to use Mercon if I remember right, but sometimes people put regular generic power steering fluid in and they get noisier than they already were.
Old Sep 27, 2019 | 12:56 PM
DBGrif91's Avatar
DBGrif91
While the gear box is out, flush the lines to remove as much old fluid as possible. The Ford pumps of this era are definitely noisy even when they were brand new, but dirty and contaminated fluid is a big contributor to it as well.
Speaking from personal experience, I’ve found 2 additives that have helped quiet the pump significantly - MAG1 power steering fluid (or sealer, to be honest I don’t recall but I found it in a gas station when I was in a pinch for some fluid) and Lucas Transmission Fix (used as an assembly lube to rebuild pump and gear - also added about 1/3 total system capacity while bleeding).
I don’t know why but both these additives made a huge difference in the sound of my pump - I hardly ever noticed it except when maxing out the turn radius.
Old Sep 27, 2019 | 01:16 PM
My4Fordtrucks
“Supposed to use Mercon” is incorrect. The correct fluid is Type F.
Old Sep 28, 2019 | 06:41 PM
Laggy's Avatar
Laggy
X2
This is correct
Old Sep 29, 2019 | 11:53 AM
brycemay907
thanks guys
Mike5737
Feb 19, 2018 02:08 PM
slayer40
General Diesel Discussion
Jul 3, 2007 01:31 PM
muscletruck7379
General Automotive Discussion
Jul 30, 2005 09:31 PM
