My flasher calls for a Wagner 224. Looks like this :
I replaced it with this one from Keep It Clean. It's a No Load Electronic Flasher :
I believe i bought it from either Amazon or Ebay. Can't remember. Regardless it works perfectly in my set up, but then remember I am running LED's in everything BUT the tail lights, as LEDS in the tail light position mess with my torque converter lock up in my application having an electronically shifted transmission. When I tried LED's in the tail lights it functioned correctly, just couldn't run them because of the issue I stated.
I thought I'd mention that I almost have signal lights again...
I've lost the in dash indicator (drivers side) and the front turn signal.
No power to the front signal socket, power when running light on but no signal.
Tried new bulbs but that's not it.
Tough to trace socket wires back as they are wrapped in harness.
Pulled dash and checked for any loose wires etc.
I have rear signal, no front.
Any ideas ?
tx
