Lost all gears E4OD
Old Sep 23, 2019 | 04:07 PM
94f250turbo's Avatar
94f250turbo
Lost all gears E4OD
So here's the skinny.
Been having to turn off the OD till about 45mph, then hit the button and then it will shift. Then about 2 weeks ago, I round a corner and start accelerating and it just revs the engine, no gear works not even reverse. So far I drained the tranny fluid replaced the shift solenoid and filter, refilled it and replaced the VSS. And nothing. Thanks in advance for the help
Old Sep 23, 2019 | 06:01 PM
trackspeeder's Avatar
trackspeeder
The tranny is shot. Time for a rebuild.
Old Sep 23, 2019 | 07:04 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
yep X2....
the OD one way Clutch failed first then when you were able to get it to move with the OD Canceled that is because it was using the Coast Clutch which is really only for braking and it's a small pack so now it has failed... the coast clutch is energized when the OD is Canceled, or when Manual 1st or 2nd is selected.
Also Failed torque converter causes loss of both forward and Reverse.
Old Sep 23, 2019 | 07:11 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
As you found out none of that could possibly cause your problem. Something mechanical has failed inside the trans. This trans is all done.
Old Sep 24, 2019 | 08:17 PM
94f250turbo
Thanks for the response, so full rebuild?
Old Sep 24, 2019 | 08:18 PM
94f250turbo
thanks, so replace torque converter first? or full rebuild with torque converter?
Old Sep 24, 2019 | 08:34 PM
ford390gashog's Avatar
ford390gashog
Full transmission with new torque converter and new cooler.
Old Sep 24, 2019 | 08:45 PM
Mark Kovalsky
If you just replace the torque converter the trans still won't operate. But it will fill the new converter with debris from the failed transmission, and then you'll need to replace the torque converter again when you rebuild the trans.
Is there any type of rebuild other than a full rebuild? Do people rebuild just part of the transmission? Why would someone do that?
That's the right way to do it.
Old Nov 19, 2019 | 10:18 AM
94f250turbo
How do I tell which rebuild kit will work for my e4od?
Old Nov 19, 2019 | 07:33 PM
Mark Kovalsky
A master rebuild kit that says it is for a 1994 diesel E4OD will be correct.
Old Dec 19, 2019 | 01:30 PM
94f250turbo
So buttoned up the pump and began to start on the valve body and the output shaft doesnt turn clockwise or counterclockwise, advice anyone?
Old Dec 19, 2019 | 02:05 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Is the Park Pawl Engaged ... Item 158 ??
https://www.supermotors.net/registry/media/543732_1
Old Dec 19, 2019 | 02:19 PM
94f250turbo
No it's not I went to turn it so it would engage and that's when I said uh oh
Old Dec 19, 2019 | 02:39 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I had to ask
but yeah ... something too tight, did you have to replace any Hard Goods ?
maybe incorrect shimming ...
I've also seen case where drums were not seated into all the clutch discs too.
of course it won't spin with just a flip of the fingers, but it should turn fairly easy.... I use the ATP assembly lube along with Tranny fluid when I put em together too so they are not Dry.
Old Dec 19, 2019 | 03:04 PM
94f250turbo
Tried vice grips with a rag and it moves about a quarter of a inch both ways then stops like its locked. I just used tranny fluid could find my assembly line and the wife wont let me use hers...lol
