This sucks
Old Sep 22, 2019 | 06:17 PM
Branden Heine's Avatar
Branden Heine
This sucks
Well the truck is finally home but the cancer is worse then I thought it was it needs
floors
floor brace
door jambs
cab mounts
cab corners
In my opinion to far gone to save so now I’m on the hunt for a solid cab
Old Sep 22, 2019 | 06:24 PM
Christmas's Avatar
Christmas
I do believe they sell all of those panels. Guys on this site do it all the time.
Old Sep 22, 2019 | 06:26 PM
Branden Heine
I know I have the panels to do it put I don’t have a welder so I’m gonna have to pay someone a good chunk of money to do it
Old Sep 22, 2019 | 06:38 PM
Christmas's Avatar
Christmas
Welders are cheap but skills are required, but attainable. Matter of desire. There are plenty of nice trucks on Ebay and most are turnkey. If you want to cut and run I'm sure there are plenty of good parts you will have no problem moving on.
Old Sep 23, 2019 | 06:21 AM
Itsmyford's Avatar
Itsmyford
It's not that bad...
Don't get discouraged. All of those issues can be fixed. I believe the components you will need are all readily available. And, your truck is common enough that you should be able to find lots of stuff at scrap yards. Assuming your mechanicals are in working order, make a list of structural repairs needed. Then you can tackle them as time and $$ allows.
Depending on your goals, it's very rewarding to fix your own stuff. Welders can be purchased quite reasonably and are alot less expensive than paying someone to do that level of work. If you decide to do the work yourself, you will need to develop welding skills. There are a ton of resources online that can help. Then practice making those welds on similar material. And don't forget to ask for help. Welders, like many craftsmen, don't mind sharing their knowledge. I had a delivery guy come to my garage one day. He was a full time welder when he wasn't doing this side job. He saw me struggling with some floor pans and got off his truck to show me what I was doing wrong.
Excepting the cab corners, I have made all the repairs you listed and I am a novice welder at best. Good luck and don't give up on that cab just yet. Tim
Old Sep 23, 2019 | 06:36 AM
66v8baby's Avatar
66v8baby
Whole floor pans for the '65/66 2WD are not available in reproduction. If you don't already have the skills to do body work, the amount of time to learn to do it right is not insignificant. I would recommend finding a better starting point. Part it out if you can or rebuild the engine, rear axle, and front suspension and have them ready to install in another truck.
Old Sep 23, 2019 | 06:54 AM
Cheddar's Avatar
Cheddar
I use a harbor freight MIG welder that costs less than you paid for the truck, not junk its been welding fine for many years, as alluded to probably 9 out of 10 of these trucks in the wild need mostly these same things. I'd also advise you to get one and learn how to use it, I always say that torches and welders set you free. Good learning experience for a young whipper snapper like you, I worked in a metal shop and learned to weld when I was your age, it will serve you well as you continue with the madness of old trucks and anything structurally / mechanically really. And see, now you'll know right where to look the next time you find one in the rough.
Good luck,
Ed
BTW that's quite a nice tool box for a 17 year old
Old Sep 23, 2019 | 07:24 AM
Branden Heine
Good luck,
Ed
Yeah I got that tool box a couple days ago but I’ve taken shop class the last 3 years of my life I can lay down pretty nice beads I just need the welder
Old Sep 23, 2019 | 07:41 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Christmas is right,I ‘d say ditch it.
I guess you’re in high-school, or just past it? Borrow 5-6k from your folks, search out a nice running truck from the southwest or Cali, and you and you dad can do a fly-n- drive back to Kansas in your new running truck.
Or, years , headaches, and a fortune later, MAYBE be driving that one. More likely, you’ll sell it after sinking money into it, not even recouping the costs. I have seen this scenario countless times over the years. For everyone person that takes a project like this to completion, there are twenty, that do not. Most are gone from FTE in a year. Ask NumberDummy.
Old Sep 23, 2019 | 08:01 AM
Branden Heine
My dad does not like these older pickups he wants nothing to do with them
Old Sep 23, 2019 | 02:03 PM
Crop Duster's Avatar
Crop Duster
I was your age once. Growing up here in the land of make do. You want something to drive not a two year project. What I would do is get it where it will run and drive and maybe stop a little. If it will do that get some sheet metal and pop rivets patch up the floors so you don't get frostbite driving to school and have fun. You have the rest of your life to find another one or fix that one.
Old Sep 23, 2019 | 02:24 PM
Christmas's Avatar
Christmas
Road signs an sheet metal screws worked best.
Old Sep 23, 2019 | 02:30 PM
Branden Heine
The only problem is my front cab mounts are so bad the cab tilts forwards slightly is there any way to fix that
Old Sep 23, 2019 | 03:05 PM
62SY4's Avatar
62SY4
Take some pictures of the pinchweld where the firewall meets the floor/ cab mount. Basically take a picture of the bottom front of the cab, by looking into the wheel well.
You may be able to slip a pan and cab mount under the existing rusty mess to get by until you have the tools/time or a donor cab is located.
To some point of some of the previous posters, I have a 66 that I bought off a guy who was driving it as is. The bottom half of the fire wall, both floor plans and cab mounts are made from street signs. I wouldn't try to go cross country in the truck, but it hauls firewood. He used it for the same although he was driving to his farm which was several miles down a heavily trafficked US highway.
Old Sep 24, 2019 | 05:08 AM
Crop Duster
Redneck cab mounts
Like I said before this is the land of make do. The PO was a body man at the local Ford place for 25 years. He got this truck in 1982 and it was his daily driver until 2001. He said these cab mounts were on it when he got it.
These can be shop made out of 3/16 plate and installed with little more than an acetylene torch and a hand drill without taking the truck apart. I still have them so if you want to try it let me know and I will measure them an post the dimensions.
