DEF 2011 up
Old Sep 21, 2019 | 02:51 PM
Jacsent1's Avatar
Jacsent1
DEF 2011 up
Is there a DEF TROUBLESHOOT section or discussion, something that provides pinpoint test recommendations based on codes??
replaced pump and sending unit/tank heater. Keeps throwing same codes. Worked awesome for 3 days after clearing codes p208b, p208c. Suspect I have a wiring gremlin....
Old Sep 21, 2019 | 08:08 PM
senix's Avatar
senix
you might check all the connections and clean them and ensure they have good contact.
Old Sep 21, 2019 | 10:05 PM
Jacsent1's Avatar
Jacsent1
I’ve tried that on the tank end.. need guidance or pinpoint tests for specific codes to go further.
All in all, replaced heated line to injector, pump/sending unit and tank heater.
P208b/c have nothing to do with injector hence leaves wiring.
Looking to delete the bs to be honest. Every 2 yrs I go though this.
Old Sep 23, 2019 | 08:36 PM
denverhank's Avatar
denverhank
Check with your dealer. There is an extended warranty on the DEF heating system. Your truck might be covered.
iateatoad
13
Dec 8, 2012 10:35 PM
crazer42
Apr 17, 2010 04:48 PM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
choppersinc
1983 - 2012 Ranger & B-Series
Mar 1, 2005 08:29 PM
