Engine Temp Sensor Part ID
Old Sep 21, 2019 | 09:29 AM
PatmanPS's Avatar
PatmanPS
The Engine temperature light comes on occasionally especially when the water temperature is Not yet warm. I understand that this is likely due to the water temperature sensor that is to the left of the water pump. I was able to get a part that I thought it was the right one, however after pulling out the old sensor I discovered it was the wrong part. Now searching for the right part I am unable to know exactly which part is correct. Another words there are lots of water temperature sensors available on the market but the typical auto parts stores don’t clearly distinguish which one is for the water Temperature sensor that controls the light.
Would anybody happen to know the correct part number for that sensor. The brand is not as important to me is just been able to find the right part.
Old Sep 21, 2019 | 11:57 AM
Hit Man X's Avatar
Hit Man X
Sensor for that dummy light is on the passenger cylinder head as I recall.
FWIW, I removed all that crap from my truck. Only think that works is the 'wait to start'
Old Sep 21, 2019 | 12:38 PM
PatmanPS's Avatar
PatmanPS
Thank you. I have found the sensor and remove it. Once I removed it, I found that the part given to me by a local parts store was incorrect. It would not physically. fit.
I'm looking to see if anyone can point me to a reliable part number. If all else fails, I'll try a Ford dealer. But there is always a premium going that route.
The good news is that I am confident it is a bad sensor or wiring. The truck is not over heating.
Old Sep 21, 2019 | 01:44 PM
farmert's Avatar
farmert
You can find a lot of parts numbers in the mod/tech sticky at to top of the page. It shows the Ford number as f4tz-10884-b.
Old Sep 21, 2019 | 02:29 PM
PatmanPS's Avatar
PatmanPS
Awesome, Thank you. I'll look at the mo/tech sticky as well.
BIG J82
Apr 15, 2011 03:05 PM
BlznOlie95
1978 - 1996 Big Bronco
Oct 23, 2006 10:31 AM
joners
Dec 21, 2005 12:48 AM
dsheleg
Feb 17, 2005 09:20 PM
Greg 79 f150
Sep 5, 2004 10:43 AM
