Multiple Small questions! (bed liners, shifter linkage, selector correction)
Old Sep 20, 2019 | 07:55 AM
Magnum3672's Avatar
Magnum3672
94 F350 with 7.5
My truck bed is in really good shape for it's age (few dings, minimal surface rust, no holes) and I'd like to get a liner for it. Any tips on professional vs retail? Things to look for in a good liner? Spray in vs drop in? I'm not particularly looking to change how the truck looks, I just want a durable liner to keep protecting the bed from further issues and possibly add some long term value.
Second, I made a post a couple days ago about my ignition sticking when turning the truck off from running. I'm beginning to think it has something to do with the shifter (it's an automatic) not being perfectly lined up when it's in "park". Is that something pretty simple to tighten up? Any quick resources you guys can show me?
Last, the gear selector on the gauges is just absolutely slammed to the far right on the cluster (the PRND321 gauge) any resources on fixing that real quick?
I know a lot of this is pretty simple stuff I could google but half the time I get the wrong year when I search and my google-fu is pretty good so anything you guys can help me with will be appreciated. Also, sorry for any improper terminology, I've got a head cold and a bad case of brain farts.
Thanks guys!
Old Sep 20, 2019 | 11:06 AM
jas88's Avatar
jas88
Sounds like the little cable that moves the needle is either broken or just disconnected. Pull the kick panel under the steering wheel and look up at your steering column. You are looking for a thin white plastic tube that has the cable inside of it.
I recommend you get a factory Ford manual for your truck, it will cover this plus the shift linkage adjustment.
Old Sep 23, 2019 | 08:59 AM
Magnum3672's Avatar
Magnum3672
Any suggestions for which brand of Ford manual to buy?
I can't seem to find the ford specific one.
Old Sep 23, 2019 | 09:59 AM
tscholz2001's Avatar
tscholz2001
Definitely a Haynes manual. Worth the money.
Old Sep 23, 2019 | 10:18 AM
ewalt98's Avatar
ewalt98
I have a drop in bed liner for my truck. Works pretty well, but you need to mount it via screws or other to the bed sheet metal. And, they can trap moisture underneath, which can lead to rust. I would recommend spray in.
I got my liner for free, and the bed itself sags 2-3 inches between the cross supports from heavy loads in the past, so the drop in liner gives me a relatively flat bed floor.
Old Sep 23, 2019 | 07:06 PM
Edgethis's Avatar
Edgethis
Good advice has been given here. A spray in liner will add some value, a Drop in isn't worth the money. Also be careful of the rubber mats that lay on the floor, they can trap moisture as well.
watch this
May 15, 2012 08:49 PM
jbhowat
Jan 17, 2009 05:51 PM
daggerNC
27
Oct 31, 2004 12:55 AM
khendrix
2004 - 2008 F150
15
Sep 7, 2004 09:29 PM
