Sponsored by: Auxito
No overdrive
Old Sep 19, 2019 | 07:12 PM
dbreckman's Avatar
dbreckman
No overdrive
I have a 99 SCAB 4X4 that has recently stopped shifting into overdrive. I have read where there is a clip on the overdrive servo that breaks and blocks the plunger. If I understand right this requires getting into the valve body so I figured I'd just disengage the overdrive and go 3 gears (1st - 3rd shift fine) until I could get into the tranny. That's when I noticed that the overdrive selector has no effect on the shifting. Is it possible that the overdrive selector malfunction could cause the no overdrive symptom?
Old Sep 19, 2019 | 08:19 PM
Bluegrass 7's Avatar
Bluegrass 7
No for the following reason; at every engine restart the PCM turns the OD function on again.
If it does not work, it's either a trans fault or an electrical fault.
Note the Lock-up function is separate.
Under a no fault condition, if the OD is turned off (light on), Lock-up will occur in third gear unless the switch is not signaling the PCM.
The light and switch functions are actually separate but built into the switch form.
This is why there are 3 or 4 leads going to the switch assembly.
To add, if the Lock-up does not work, the trans will generate more heat from fluid shearing in the converter.
Old Sep 21, 2019 | 09:48 PM
dbreckman's Avatar
dbreckman
Changed the gear shift lever out, now the overdrive selector works. I can at least drive the truck now. I'm hopeful someone can point to something else that would cause only 4th/overdrive to slip. I really don't want to drop the valve body if I don't have to, if it can even be done without pully the whole tranny.
Old Sep 23, 2019 | 09:01 PM
70f100longbed's Avatar
70f100longbed
It's most likely a broken clip. No way to get around it without dropping the valve body. A piece of the clip gets into the valve body and hangs up a valve.
Cracker289
Aug 24, 2012 12:44 PM
easttxguy37
2004 - 2008 F150
May 20, 2007 09:47 PM
chews32
Oct 10, 2004 06:04 PM
kerry2u2
Apr 18, 2003 11:07 PM
