Sponsored by: Real Truck
Transmission or transfer case
Old Sep 19, 2019 | 06:20 PM
Maddogpedigo's Avatar
Maddogpedigo
While driving 99 ford f250 super duty diesel 4x4 I heard a loud pop now it won't go forward or backwards. Is it the transmission or transfer case.
Old Sep 19, 2019 | 06:57 PM
00t444e's Avatar
00t444e
Could be either one or neither of them, going to need more info than that.
Old Sep 19, 2019 | 06:59 PM
Maddogpedigo
What info do you need
Old Sep 19, 2019 | 07:00 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
With the transmission in park will the truck roll or does park hold it?
If it rolls the problem is in the transfer case. If park holds the problem is in the transmission.
Old Sep 19, 2019 | 10:20 PM
droldsmorland's Avatar
droldsmorland
Mark makes a good point ...as usual... buuuttt...
We dont have access to a crystal ball. Not to be a wise-***(well maybe a little) but if you want accurate troubleshooting responses we need all the facts.
Truck miles.
Daily commuter, workhorse or plow truck?
Service history...trans, xfer case, diffs etc...Fluids ever been changed?
Have you dropped the trans, xfer case and diff fluids looking for evidence of failure(chunks)? If not thats where Id start after verifying what Mark said.
When and how did the trouble occur...at 90mph or backing out of the driveway? 4 wheeling or normal commuting?
Could be anything from a bad diff, snapped axle, ring/pinion. broke trans or xfer case to your e brakes getting munched up(if 99 has disc rears).
Old Sep 19, 2019 | 10:49 PM
99f350sd's Avatar
99f350sd
How about a flex plate failure?
Old Oct 16, 2019 | 11:52 AM
droldsmorland
I hate dead-end threads.
OP...Please close the loop here.
Did any of this info help? What was the fix? Or did you junk it and buy a Dodge?
78 RedandWhite
Jan 31, 2011 07:29 AM
kmonty20
Jul 21, 2007 01:26 PM
bass_man_ct
Jun 21, 2005 10:04 PM
cryptonik420
Dec 3, 2002 12:57 PM
