Dad's 77 highboy resurrection
Two P/S hoses, pressure and return, route from the pump to the control valve. Two P/S hoses, pressure and return, route from the control valve to the hydraulic ram cylinder.
Garrison Power Assist P/S: 1973 F250 4WD, 1974 F250 4WD before serial number T80,001.
Bendix Power Assist P/S: 1974 F250 4WD from serial number T80,001, 1975/76 F250 4WD, 1977 F250 4WD before serial number Y20,001.
Pic has wrong caption, includes 1977 F250 4WD before serial number Y20,001.
Fordguy, What do you mean by "upgraded Bendix box"? He didnt mention it when I spoke with him on the phone. Mine has the Bendix system from the factory and not the Garrison.
440, did you have to cut a section out of your frame in the engine crossmember to install the Benchwork kit power gearbox?
I sent my original manual gearbox in to Blue Top as well since it seemed to be oozing grease from a seal.
Edit* I believe they have a post about what they do... I am trying to find it. Will post it up when I do.
Heres a quick excerpt from their site
We now machine all Ford pickup housings to put in needle bearings in the lower sector shaft portion of housing. Most of the 68-79 pickups did not have bearings for the sector shaft so after time the shaft would wear into side of housing. This is something that most re-builders won't do anything about. .
We are happy to be stocking and offering rebuild services for control valve units and full rebuild of all power steering cylinders. Control Valves are re-manufactured, tested and balanced. All cylinders are cut open to replace piston rings and to replace chrome shaft. Cylinders are re-welded and tested for leaks and internal bypass.
I call it an upgrade because well, they are making it better lol.
I also posted the parts catalog pic of the two Power Assist P/S systems so people can see the difference between these two systems.
Edit: No 1965-21st century Ford/Saginaw P/S box, whether it's from a Passenger Car, F100/350, Bronco, Econoline, Ranger, Bronco II etc. has bearings on the sector shaft.
Ford/Saginaw P/S introduced in 1965 Galaxie/LTD, introduced in F100/250 2WD & F350 in 1969 from serial number D96,001.
I've been looking this crap up in Ford truck parts catalogs since these trucks were new, so I KNOW what's correct and what isn't.
Yeah yeah we all know you know everything. New flash not everyone uses the precise perfect terms all the time... hell highboy isn't even a ford term yet people use it. So I said box instead of some other term...We all knew I was talking about the bendix system and anyone familiar with it knows the differences between true power steering and these systems. No one was asking for you to dissect and post a vomit of knowledge stating why my random post was wrong.
Installation was a breeze but I had my engine out at the time so that made it a little easier.
I thought there was some fabwork to get that kit working in Highboys. Sorry for the thread hijack but i think you'll appreciate the answers too OP lol
Unfortunately I didn't get any pictures of the steering components before sending them off. But the prices were $290 for the cylinder, $300 for control valve(drag link), and $335 for manual gearbox. I had intended to just reuse the manual gearbox but after seeing the oozing grease and feeling a bit of play I decided to send it in too. They do offer an exchange service but I specifically told him I want my originals rebuilt and returned. He said that was no problem. I wanted to do this because I KNOW they have not been abused and I am certain the cores are good.
I like how Blue Top replaces the cylinder shaft which tends to wear in the center and leak. They also offer the bushings for the end of the cylinder rod.
I already have all the new hoses, I think there was 4 total.
Bendix control valve(drag link)
Bendix steering cylinder
Manual steering gearbox used in conjunction with "power assist" steering
The bearing upgrade Fordguy is referring to is something that the Red Head/Blue Top companies offer but it does not apply to the manual gearbox in the highboys. It is available to the power steering gearboxes used on the non-highboy trucks of that era.
As I understand the original bushing used wears and causes slop in the gearbox, but with the housing machined out and the bushing replaced with the bearing this doesn't occur.
Numberdummy is there somewhere I can purchase a Ford parts manual for my truck? I remember seeing reprints on Ebay years ago but now I cant find anything. I have all manuals for everything I own, except a parts manual for this truck.
International 510 PayLoader loading highboy chassis onto trailer to go to machine shop.
Link to a parts catalog cd
Yeah hmm I may mention having mine rebuilt vs gambling on a core rebuilt from someone else. I'm not there yet in my build but collecting info nonetheless
Also I know you have to cut and notch the frame if you use steering parts from a 78/79. Maybe you were thinking about that ?
A few pictures of the frame repairs.
Looks a heck of a lot better than it did. I will remove them for sandblasting then reinstall after paint.
Right rear frame gusset repair
Left rear frame gusset repair
I also wanted to get the old brake calipers off before sandblasting the chassis. That was easier said than done. The little slider wedge piece was rusted fast on both sides. I soaked it with PB Blaster for weeks. All I did was mushroom the ends with the hammer and punch trying to drive it either direction. I did unbolt the caliper and get the caliper brackets to slide back and fourth but the wedge piece wouldn't move. I finally broke out the grinder and cut a groove in the wedge piece to allow the caliper bracket to be removed. Then I was able to beat the wedge out.
Removing the calipers the hard way....
I also removed the clutch/brake pedal assembly from the original cab for later installation. I read on another thread NumberDummy said there were something like 30 pedal and bracket combinations! So I wanted to ensure I used all the stuff from my highboy to make sure its correct.
I have an upcoming trip for work and I was trying to get the chassis sandblasted and coated with the KBS Rust Seal, and BlackTop chassis paint before I left but my sandblaster is busy so it wont happen til I get back.
Hey, those HUBCAPS that make you nauseated.... If you don't want 'em, I sure would like to get my hands on 'em. I am doing a resto on my '78 F150 and I am working on getting a set of those together. I have a set but i need parts to get one good set and a spare or 2.
PM me if you want to see 'em leave your place. I would hate for you to throw up everytime you walk by 'em.....LOL.
Keep up the good work!
Mike
I need some opinions on leaf springs. I plan to leave the truck stock height and had intended to put new leaf springs all the way around. Unfortunately by the time I pay shipping (about $250) I'm looking at about $800 to my door with new bushings installed.
I see nothing wrong with the original springs other than a lot of rust. Not sure if that degrades them much in their function. None are broken, and they dont seem to sag for 42 year old springs. But changing the spring bushings would probably be a nightmare on such rusty springs.
Any thoughts on reusing the old rusty springs and replacing the bushings? They will be sandblasted and painted. will sand get stuck between them and wear them with use? Does the rust make them brittle?
and power assist cylinder for less than $1000
