1 ton alignment
Old Sep 22, 2019 | 09:27 PM
Yahiko's Avatar
Yahiko
Originally Posted by Y2KW57
Small sheets of teflon, slick plastic, or other slipper substrates can be doubled up under the contact patch of the two front tires so that toe can be checked with the suspension at ride height, without jacks even, if one lubricates between the two slip plates beneath each tire.
For light aircraft we used 2 aluminum sheets with some grease between them.
One could use a steel plate with an aluminum top plate with grease.
rewillia
Texas Chapter
Jun 16, 2019 01:14 PM
asok
Washington Chapter
May 9, 2010 09:01 PM
mstaser
Jul 4, 2008 07:34 PM
topfisherman
1978 - 1996 Big Bronco
Jul 27, 2004 06:25 PM
