Blower motor resister replacement
Old Sep 17, 2019 | 11:25 AM
Motate455's Avatar
Motate455
Anyone replaced the blower motor resister? 1977 f250 simple version (defrost and heat, not hi-lo).
My blower motor works when powered, so I am replacing the resister. I see where the wire plugs in, and it looks like two rivets instead of screws to remove it
do I remove the blower motor and get to it from the inside of the housing?
or are those rivets really something else that can be removed somehow?
thanks.
Old Sep 17, 2019 | 01:29 PM
dlburch's Avatar
dlburch
have you tested the fuse, switch and wiring first?
Old Sep 17, 2019 | 01:59 PM
Motate455's Avatar
Motate455
I’m running a couple things down but when I unplugged the wire from the blower resister, I touched the blades and they were loose , so I was starting there.
I’ll be tracing more wires tonight and I’ll se if I can power the switch to see if it works
Old Sep 17, 2019 | 03:17 PM
dlburch's Avatar
dlburch
it could definitely be bad, BUT when the fan speed switch is in the high position, it bypasses the blower motor resistor...so if your fan doesn't work on High, there are other issues besides the resistor...
Old Sep 17, 2019 | 04:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C9AZ-18591-A .. Blower Motor Resistor - Use with heater or dealer installed A/C / Obsolete
1973/79 F100/800 // 1975/79 Econoline // 1978/79 Bronco /// 1969/72 Galaxie/LTD
Shown as 18591 in pic:
Old Sep 17, 2019 | 05:26 PM
Motate455's Avatar
Motate455
Fuse looked good but was bad at the cap so replacing that gave me high speed now. Ordered the resister, we’ll see if it is what it is supposed to be when it shows up
Old Sep 18, 2019 | 09:47 AM
5851a's Avatar
5851a
The rivet is plastic sometimes. It should have very small seam on the side of the head. Pry the top of the head up from the body of the rivet. Should come up an 1/8 inch. Rivet should pull out with a little wiggeling. They are reusable.
On the order of this.
Tag2331
Aug 8, 2015 01:42 PM
AlbyVA
6.4L Power Stroke Diesel
Jun 14, 2014 05:50 PM
Tormz
Dec 4, 2013 09:48 PM
lippsenator
Sep 18, 2010 04:46 PM
drpratt
Apr 14, 2009 09:50 AM
