Missing issues
Old Sep 16, 2019 | 05:16 PM
RonMacLeod's Avatar
RonMacLeod
Missing issues
Just had my injectors replaced and I now have a missing problem.
Truck idles fine. Get it to 2000/2500 rpm and it starts to sputter.
Thoughts?
Old Sep 16, 2019 | 07:32 PM
PSU4ME's Avatar
PSU4ME
How do the pins on the uvch look? Did you touch/replace anything else?
Old Sep 16, 2019 | 07:36 PM
PSU4ME's Avatar
PSU4ME
Also, how old is the cps, have you changed it recently?
Old Sep 16, 2019 | 09:43 PM
oldbird1965's Avatar
oldbird1965
Injector O rings need replaced.
Old Sep 16, 2019 | 10:21 PM
Action4478's Avatar
Action4478
OMG..........Its possible you still have air in the system. But by all means do all that other crap first .
Old Sep 17, 2019 | 07:03 AM
867.309's Avatar
867.309
Thoughts?
I hate your avatar so I'm not speaking to you.
Still don't understand the resistance to diagnostic software and pressure gauges. Can't get past it, or the avatar.
Old Sep 17, 2019 | 08:08 AM
knottyrope's Avatar
knottyrope
low on oil or air in system
low fuel pressure
injector orings
IPR or orings
bad ICP
bad BARO
bad MAP
EBPV stuck closed
faulty IDM wiring
weak HPOP
Old Sep 17, 2019 | 09:04 AM
RonMacLeod's Avatar
RonMacLeod
Hi Guys
Here are the responses to your thoughts.
low on oil or air in system.... Oil is high and I have put two tanks through the new injectors already
low fuel pressure.... I will have to check this
injector orings....... Brand new Injectors so new O rings.
IPR or orings...... New IPR
bad ICP........ Will check this
bad BARO..... I dont know this acronym
bad MAP.... Will check
EBPV stuck closed......... Cleared and new sensor
faulty IDM wiring...... Checked no chaffing found
weak HPOP...... Will check
I also replaced the Valve Cover Gaskets and wiring.
Let me know if there is anything else to check.
Old Sep 17, 2019 | 10:16 AM
z31freakify's Avatar
z31freakify
What brand of O rings were installed?
Old Sep 17, 2019 | 12:03 PM
knottyrope's Avatar
knottyrope
disconnect electrical connector on ICP and see if any change in idle and see if better on a road test
BARO barometer under the steering wheel. Mine was reading 10k above sea level an defueling me. deleted since I am at sea level.
Old Sep 17, 2019 | 07:34 PM
PSU4ME's Avatar
PSU4ME
When you say you replaced the VC gaskets and wiring, what all do you mean? Sliced in new pigtails too? If so it’s possible you crossed a wire.
1996_powerstroke
13
Jul 4, 2016 02:00 PM
1996_powerstroke
Jun 20, 2016 05:04 AM
fcatpnj
3.8 & 4.2L V6
May 21, 2009 12:10 PM
catbird7
Oct 3, 2008 07:56 PM
jbacken
Jun 30, 2007 05:53 AM
