low on oil or air in system.... Oil is high and I have put two tanks through the new injectors already
low fuel pressure.... I will have to check this
injector orings....... Brand new Injectors so new O rings.
IPR or orings...... New IPR
bad ICP........ Will check this
bad BARO..... I dont know this acronym
bad MAP.... Will check
EBPV stuck closed......... Cleared and new sensor
faulty IDM wiring...... Checked no chaffing found
weak HPOP...... Will check
I also replaced the Valve Cover Gaskets and wiring.
disconnect electrical connector on ICP and see if any change in idle and see if better on a road test
BARO barometer under the steering wheel. Mine was reading 10k above sea level an defueling me. deleted since I am at sea level.
