1978 - 1996 Big Bronco
HELP! Sometimes it runs good?
Old Oct 14, 2003 | 01:44 AM
THOMASNMARTA's Avatar
THOMASNMARTA
the blocked vacuum line comes out there.
Old Oct 14, 2003 | 01:54 AM
stepman's Avatar
stepman
That's what I thought you meant. I'd have to look up your vehicle for specifics but you should have a plastic can near a frame rail that has a line to the gas tank, a line to the intake and a lineto a solenoid for controlling the release of vapors to the intake.
I gotta go for now.
Old Oct 14, 2003 | 02:35 AM
stepman's Avatar
stepman
I'm back. I believe this is where you got the code 31 from. I would think that your vent line is hooked up. Does this line that is plugged appear to come from a vacuum source? If so, it should probably go to a solennoid that is between a line running from the vapor can to the air intake.
Old Oct 15, 2003 | 12:36 AM
THOMASNMARTA
All I know is that when I pull the little hose with abolt in it, It definetly has vacuum here.
Old Oct 15, 2003 | 11:42 AM
stepman's Avatar
stepman
How small iis that hose? There should be one about 3/8" that goes from TB thru a solenoid that just "hangs" ( with a 2 wire plug on it) to the vapor can. I believe that the sol should hang off the left/front of the motor and the vapor can should be in the right front(?) corner of eng comp.
Old Oct 15, 2003 | 12:09 PM
THOMASNMARTA
Yes, It is 3/8". Do you know what that solenoid is called?
Old Oct 15, 2003 | 12:39 PM
stepman's Avatar
stepman
Can't remember the exact name of it. EVP(?) Purge solenoid(?) I think they usually sit or hang right above the front of the left valve cover.
