Recommendations Please
Old Sep 16, 2019 | 10:45 AM
R&RFord's Avatar
R&RFord
I have water coming into the cab somewhere near the top of the passenger side firewall. Hit it with water and you get a steady stream of drips coming in behind the air duct work over the passenger foot well. I do not think it is the windshield. It is not the heater core. I think it is dried out seam sealer under the cowl or a seal around one of the HVAC penetrations in the fire wall.
So, I am going to start taking things apart and hunting for problems.
Any common problem areas I should look at?
Recommendations for sealers? Seam sealers? High temperature sealers? I assume the best method is to completely remove old sealer and apply a new bead??
I will need a new carpet. Recommendations?
Thoughts and advice appreciated.
Old Sep 16, 2019 | 01:07 PM
White 97 xlt's Avatar
White 97 xlt
Don't forget to check the windshield wiper pivot while you're in there... I'm not sure if Ford had that problem, but on Mopars it was almost a guaranteed water leak!!
Old Sep 17, 2019 | 11:50 AM
R&RFord's Avatar
R&RFord
Bump to the top.
Old Sep 17, 2019 | 12:03 PM
DBGrif91's Avatar
DBGrif91
You can isolate the problem area with a hand held pressure sprayer (recommended) or a squirt gun as these will allow you to better focus a stream of water as compared to a garden hose.
Begin with the seam/opening closest to the bottom of the firewall. Spray a steady but low pressure stream of water on the seam, give it a minute and then check for leaks. Work your way from bottom to top in this way - once you see the water in the cab, the last area sprayed is the leak.
Old Sep 18, 2019 | 06:19 PM
torq'ta 5 8's Avatar
torq'ta 5 8
9fiveoh just had thread maybe it help
Chasing Water Leaks - Ford Truck Enthusiasts Forums
pwarren68-2008
19
Jan 19, 2014 10:37 AM
WVTOMMY
Jun 8, 2012 09:34 PM
crazymut
Nov 11, 2011 06:01 PM
snyiper
Oct 9, 2005 08:20 PM
Raptor119
Feb 13, 2004 10:11 AM
