Still Pinging
Old Sep 22, 2019 | 08:51 PM
  #31
Tedster9's Avatar
Tedster9
Vacuum advance, the additional timing helps to keep engine running cooler, that may be at least partly at fault.
Old Sep 24, 2019 | 08:07 PM
  #32
78Fords's Avatar
78Fords
After that first test drive it never got hot again. Vac adv is still disconnected because I am still tuning and adjusting. Would replacing the larger spring with a spring from the Mr gasket kit make for too much curve too fast? Just wondering so I don't waste my time swapping it.
So far it has been running great. I have it set to 8 ish degrees BTDC and once in a while the engine will turn over hard when I try to start it. I don't want to decrease the timing much more or I start to lose my acceleration.
I filled up my tank Monday evening so we will see how far it gets me, before I would get about 8 mpg.
Old Sep 24, 2019 | 08:36 PM
  #33
Tedster9's Avatar
Tedster9
Two light springs might be too fast, but you could try it ... only way to know. 8° initial shouldn't cause starter kickback?
Old Sep 25, 2019 | 08:21 AM
  #34
78Fords's Avatar
78Fords
It only kicks back and turns slow every once in a while. May just be my battery getting weak, im going to have it tested.
i still have to adjust my vac advance because as of now it will tap very very lightly when it is connected.
Old Oct 14, 2019 | 08:19 AM
  #35
78Fords's Avatar
78Fords
I might have to start a new thread for this concerning the starter kick back. i Slowed my initial down a little so it wouldn't kick, but now my starter makes a grinding noise when i start it, almost as if it is only halfway engaging into the flywheel, and after cranking for more than 3 or 4 seconds it might slip out. Luckily i have a lifetime warranty on my starter so i am going to swap it today. All my cables are new to the starter and battery, battery solenoid and starter are all 5 years old.
I assume it is the starter being bad from all the abuse. It has been used alot.
Old Oct 14, 2019 | 09:21 AM
  #36
Tedster9's Avatar
Tedster9
Starters have a duty cycle, solenoid/relays too. It's something like 1/2 hour rest per 10 seconds of cranking. Normally an engine in good tune will light off in just a second. Nobody follows this when it won't start, I've heard people grind on starters continuously for a minute and a half, stuff starts smoking and melting. Gaaa!!! It roasts the varnish off the windings, eventually fails, gets cored, the "rebuilders" slap a coat of paint on it and ends up back on the shelf and eventually somebody else's truck.
If you can check current draw that is probably a good indication of starter health. They draw a lot even when healthy, maybe 100+ amps, but it should not exceed the spec in the shop manual. It can choke off the ignition if they hog all the juice, makes for hard starting.
Old Oct 14, 2019 | 09:45 AM
  #37
78Fords's Avatar
78Fords
Thanks for the quick response, i love rebuilt parts, At one point i put 4 different alternators in my sisters jeep before buying new. I am going to make sure i get a NEW starter today. My engine starts immediately now that my timing is set and my choke works. but for the last 5 years is would sometimes take 5+ times cranking it to start it.
Old Oct 14, 2019 | 10:31 AM
  #38
Tedster9's Avatar
Tedster9
It's worth taking the time to make sure the mating flange on the block itself is clean and bright, grind down to shiny bare metal. This is where the electrical connection is made between the starter, not so much the bolts and hardware.
Physically tight doesn't necessarily mean electrically tight. To be honest I've never used a torque wrench on battery terminals in my life. The other day I was doing retorques on the engine after a heat cycle and on a whim I went ahead torqued the terminals to spec. These are good quality cables and terminals, not cheap lead terminals. Tight battery terminals, are important. (There is something to be said about a negative battery terminal that can be removed by hand ... but..)
Anyway then I noticed something. Normally, when I put a digital charger on the battery it typically shows a 77% charge shortly after an engine start. Now it shows 94%, which I thought kind of interesting. Slightly faster recharging from the charging system? Terminals, cables, alternators, starters, relays, all that stuff needs to be clean, and tight, or it won't work as well as it might. Now is the time to check, not January!
Old Oct 15, 2019 | 08:34 AM
  #39
78Fords's Avatar
78Fords
Very true!! i cleaned the block surface and wire brushed all of my wire ends and bolts. A new starter fixed it, the old starter was oil soaked, looks like a rear main is my next project. Thank you for the info, just thought i would share what happened when you neglect your timing for so long.
Old Oct 15, 2019 | 08:54 AM
  #40
Tedster9's Avatar
Tedster9
Yeah this is an ignition timing thread isn't it? Sounds like you're sneaking up on a really sharp tune.
Old Oct 15, 2019 | 01:47 PM
  #41
78Fords's Avatar
78Fords
haha hope so, plan is to do a power tour one day
Justin460
Dec 25, 2007 04:44 PM
Ghoti
Jan 14, 2007 07:27 AM
79 E350 rescue
Nov 3, 2005 12:58 AM
jbondi
1978 - 1996 Big Bronco
Nov 1, 2004 07:23 AM
williamwilliam
66
Jul 16, 2003 03:49 AM
