Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
330hd oil filter
Old Sep 14, 2019 | 08:06 PM
wharthog's Avatar
wharthog
330hd oil filter
Who is using what? I want to change the oil and filter on my truck but can't find a filter on any of my website suppliers.
Old Sep 14, 2019 | 08:56 PM
85e150's Avatar
85e150
Still have the can with the replaceable filter element? Motorcraft FL20. Note you can switch to spin-on, and use FL1-A. Explained here, and in another thread linked here in post 3.
https://www.ford-trucks.com/forums/1...il-change.html
Old Sep 15, 2019 | 08:41 PM
wharthog's Avatar
wharthog
I looked at that but I cant see or get a part number to go with on my search.
Old Sep 15, 2019 | 11:51 PM
85e150's Avatar
85e150
This thread mentions the following part. Post 14:
https://www.ford-trucks.com/forums/1...e-on-here.html
https://cgfordparts.com/ufolder/ford...umber=B7A-6882
Amazon Amazon
Oil Filter Conversion Kit 55-57 B7A-6882-A
There's more.
Old Sep 16, 2019 | 07:55 AM
wharthog's Avatar
wharthog
Thank you very much. I think I was just fried trying to search for information. I will be getting things going asap now.
Thanks again.
Old Sep 16, 2019 | 10:07 AM
85e150's Avatar
85e150
There might be is another adaptor also. I will try to find out later today. I found these, which are the standard FE spin on mounts. Since I don't have an FT/FE block sitting here, perhaps you can eyeball your motor vs. these pictures and illustrations and see if it bolts right up to your block, which it should. Someone will be by to confirm or condemn this suggestion.
http://www.mre-books.com/interchange/interchange13.html
https://www.ebay.com/p/Ford-FE-Oil-F...cks/1926255797
Pictures of all 3 half way through post 1:
https://www.ford-trucks.com/forums/1...rd-engine.html
Old Sep 21, 2019 | 09:29 PM
Destroked 450's Avatar
Destroked 450
Most of the F-600 thru L-800 trucks I've worked on with FT engines used the FE car adapter pointing the filter down.
Pickups use the adapter with the filter sticking straight out for the filter to clear the cross member.
Old Sep 21, 2019 | 09:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The filter will clear the cross member with the vertical adapter, but if the left motor mount breaks (a somewhat common occurrence), when the engine rears up, then comes back down, the filter will hit the cross member, splitting it open.
Old Sep 21, 2019 | 09:51 PM
Destroked 450
I had a 428 from a car in a 73 F-100 2x4, it still had the car filter adapter on the engine, I could install the short filter like is used on Mopar apps but the standard length Ford filter wouldn't fit because it hit the cross member before the filter was straight enough to thread onto the adapter.
Old Sep 21, 2019 | 11:34 PM
NumberDummy
In 1975, Ford "shoehorned" the 302 into Mustang II's (basically a Pinto). The FL-1A filter was too long, so Ford came out with a shorter version: FL-300-BDP
Old Sep 25, 2019 | 03:30 PM
wharthog's Avatar
wharthog
I found a filter insert at my local autoparts. They had one in stock. I am still going to see if I can find the adapter at the salvage yard.
Old Oct 5, 2019 | 09:04 AM
big job's Avatar
big job
I'm confused; just clean and bring the old one to Napa and get a new one. spin on or cartage my trucks have
FT and I use 2 quart spin on's. One with a 330 cartage in stock at Napa no problem........................
ClarkM
EcoBoost (all engine sizes)
Apr 29, 2017 09:58 PM
macguy
6.7L Power Stroke Diesel
16
Oct 23, 2012 07:58 AM
timbuctooCal
Offroad & 4x4
Aug 20, 2010 07:42 PM
zstyle01
Sep 6, 2007 05:59 PM
rswhitmore
Oil & Lubrication
Aug 4, 2007 02:04 AM
