Tranny question
Old Sep 12, 2019 | 07:53 PM
'77F250C's Avatar
'77F250C
Tranny question
Transmission Code
CODEYEARSPDDESCR.TYPE
A'73-'794ManualNew Process 435
C'73-'793ManualFord
E'73-'794Manual
(D.S.O.) *
Warner T19
F'73-'794ManualWarner T18
G'73-'793AutomaticFord
* Domestic Special Order
J'793AutomaticFord
K'793AutomaticFord
P'73-'794ManualWarner T-19
X'78-'793AutomaticC-6
(Fleet only)
Z'773AutomaticC-6
(Fleet only)
SOURCE: 1973-1979 Ford Truck Master Parts Catalog
Under G, what does Automatic Ford mean for the tranny ? Ford is the name given to the tranny ? I guess what I'm getting at is if someone asked "What tranny do you have?", you just say Auto Ford ? Hope this makes sense.
Old Sep 12, 2019 | 08:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thru 1978, the idiots at FoMoCo used the G trans code for all A/T's.
Since G only decoded to "Automatic Transmission," one had to know which trans was available with what engine.
1979: The idiots finally woke up: G = C4 & K = C6.
What year/series is your truck, what engine?
Old Sep 12, 2019 | 08:05 PM
85e150's Avatar
85e150
G being a Ford automatic, it would have to be a C6 for that year. You have a 351M, right?
See post 3 regarding the "G" code and the applications of the other suspects here, the C4 and FMX, indicating they would not be used in your truck with that engine.
https://www.ford-trucks.com/forums/1...on-code-j.html
85e150's Avatar
85e150
Shucks, beat me to it again......
Old Sep 12, 2019 | 08:09 PM
'77F250C's Avatar
'77F250C
LMAO !! 1977 with the 351M. Good info. Thank you.
Old Sep 12, 2019 | 08:14 PM
NumberDummy
... C6 ...
Only A/T's available in 1979 F100/350, Bronco & Econoline: C4 & C6.
The C4 was used with 300 & 302, but the C6 was also available with these engines.
351M/400/460 = C6.
C4 has 11 trans pan bolts, C6 has 17 trans pan bolts and the shape of the C6 pan resembles the state of Utah.
roger dowty
1978 - 1996 Big Bronco
18
Jun 3, 2007 12:40 AM
gwenismine
Nov 15, 2005 05:38 PM
iceman06
Jun 9, 2005 10:44 PM
TDN
Mar 10, 2005 06:03 PM
DT 466Man
2004 - 2008 F150
13
Dec 1, 2003 02:34 PM
