Header issues
Old Sep 12, 2019 | 03:47 PM
crucialprospect's Avatar
crucialprospect
Header issues
I got fenderwell exit headers on my 460 4x4. Long story short, spun the distributor this past weekend and was glowing everything from the heads to the exhaust pipe. 10 years ago, my quick clearance fix was to wrap everything in heat wrap that is close to that area. I believe there are 3 harnesses, the clutch slave hose, the speedo cable, and the rear brake lines. Up to this point I didn’t have an issue, so I never fixed it permanent. Now I have a mess to clean up. First off, what wiring runs in these harnesses by the driver side firewall? I melted one wire completely and need some ideas on how to permanently fix it.
Old Sep 12, 2019 | 03:52 PM
crucialprospect
The damaged area I need to fix, notice the header clearance
Speedometer cable melted and seized
Wire harnesses in that area, what do they control? I’m assuming taillights, fuel tank switching controller and transmission controls?
Header clearance
They wire that was completely burnt and severed. It was in its own plug, I’ll research the number and replace.
Old Sep 12, 2019 | 04:13 PM
crucialprospect
The melted wire plugged into the transfer case, I assume it was the 4wd engage light. No biggie there, thank goodness it wasn’t something that could have burnt the truck down (more than it was already!)
i figure i can undo undo the brake hardline and route inside the frame rail to keep out of the way of the headers. Still kinda stumped about the clutch hose and other harnesses. I figure the harness I can try to reroute or make a heat shield, but all I can figure for the clutch hydraulic line is to put that spark plug boot protector by dei on it.
Old Sep 12, 2019 | 07:03 PM
Rembrant's Avatar
Rembrant
You can buy that thermal heat sleeve tubing for fuel lines....I was going to put one on my clutch line and forgot to. It's not much of a concern on my truck as I have lots of clearance, but I was going to do it for good measure anyway.
Old Sep 13, 2019 | 05:20 PM
crucialprospect
I used a dei heat sleeve when installing the new odometer cable today, got one for the clutch hose too. I’ve got two toasted harnesses though, before I cut and re-splice then, is there any chance I can find nos ones and unplug? Pretty sure one is the taillight harness and one is the fuel tank switching harness.
E6TB 14405 EA
E6TB 14405
are the numbers on the harnesses, sounds vague and generic, but it’s worth a try.
Old Sep 13, 2019 | 05:22 PM
crucialprospect
Goes into a 4 wire plug
The cluster of melted wires
Goes into a 8 wire plug
Old Sep 13, 2019 | 05:43 PM
crucialprospect
Can’t seem to find any plug and play harnesses online, anyone else know a source?
If if I cut and splice I’d like to retain factory colors, anyone know where to get bulk wire in factory colors?
Old Sep 13, 2019 | 09:01 PM
Franklin2's Avatar
Franklin2
You didn't say what year your truck is. I picked a 1986 with a 460, and said I was looking for the engine. This junkyard came up in Kentucky. The salvage yard is the only place you are going to get a factory harness. The lighting harness may work for a f150 thru f350 with all kinds of different engines. But your fuel switching harness will have to be a 460 equipped truck, they had their own special fuel system.
1985
Engine Assembly
Ford Truck F350
RUNS GOOD QUITE BLOW-BI-4140541,000A7558$400Hawkins of Mayfield Inc. USA-KY(Mayfield) Request_Quote 1-800-633-7047 Request_Insurance_Quote
Old Sep 14, 2019 | 04:41 PM
crucialprospect
I guess I’m just gonna nite the bullet and splice in about a 12” section with each color wire.
Old Sep 14, 2019 | 04:46 PM
Franklin2's Avatar
Franklin2
If it's only that short distance, I would not worry about the colors either. It should not affect troubleshooting purposes to have the wrong color wire in that short piece in the middle of the harness.
CB-R
Exhaust Systems
Aug 15, 2012 04:28 PM
Dimitri.c
Aug 21, 2009 08:51 PM
camccardell
Mar 23, 2008 10:20 PM
Vince Perino
Aug 28, 2004 05:36 PM
77460ford
Jul 19, 2002 02:49 AM
