Won't Start
Old Sep 9, 2019 | 04:26 PM
vlvorcr's Avatar
vlvorcr
Won't Start
New to this forum and I need some help. I have a 2014 F550 RV. When I went to start it last weekend it would not turn over. No solenoid click, no nothing. Batteries are good. Aux boost from the RV house batteries didn't help. No voltage at the solenoid when the key was on start. Finally found that problem by checking fuses (they were ok) and swapping relays (one was apparently bad). Now it turns over just fine but it will not start. Any advice? Unfortunately, I don't have a code reader.
Gary
Old Sep 9, 2019 | 06:16 PM
Just Strokin's Avatar
Just Strokin
here is a diagram...maybe will help
Old Sep 12, 2019 | 01:24 PM
vlvorcr's Avatar
vlvorcr
Ok. I got an OBDLink reader. It tells me I have no confirmed or permanent codes. Two pending; P0627 and P20C2. Since these are pending, they shouldn’t be keeping the truck from starting, right? Engine cranks just fine but just won’t catch. I‘m new to this OBD code diagnostic stuff so any help would be appreciated.
Gary
Old Sep 12, 2019 | 01:41 PM
Just Strokin
P0627 could prevent the engine form starting.
Can you hear the fuel pump mounted on the frame that contains the fuel filter humming or running?
P0627 - Fuel Pump "A" Control Circuit / Open
OBDII Codes.
OBD system - General Overview and Operation Summary
Old Sep 12, 2019 | 02:09 PM
vlvorcr's Avatar
vlvorcr
Larry,
Thanks for the quick reply. The problem is fixed and it now runs. The problem was me! When I was mucking around in the fuse box and found the bad relay that was keeping the starter from turning, I put a diode related to the full pump back in the wrong slot. As soon as I fixed that it started right up. I'm still getting the pending P0627 code but I assume that will go away after it runs for a while. Thanks again.
I'm sure glad I didn't have it towed to the shop. I would have to wear a bag on my head every time I showed up there!
Gary
Old Sep 13, 2019 | 08:03 AM
vlvorcr's Avatar
vlvorcr
Larry,
One last question. Where can I get diagrams like you provided for the rest of the systems?
Gary
sherifflittle
May 20, 2018 07:09 PM
Cody Abshire
Mar 23, 2017 11:43 AM
Trailblazed
Oct 4, 2009 01:26 PM
wbhinton
Sep 5, 2006 10:40 PM
