I promised I searched before I asked
Trying to figure out why my brake pedal won’t return to the normal position and brake lights staying on. This happens only after driving for a bit and warm up. After reading many of threads it all points to the brake booster or master cylinder. Found some really good info just not the answer to my specific problem. In y’alls opinions where should I start ?
Brake booster piston stuck? I assume the pedal stays down halfway or somewhere in between? Have you attempted to bleed all four brakes yet? I'd start with the easy steps like that first and then move onto replacing components after some investigation. Also check your vacuum line for breaks or dry rot going to the booster. Someone more common with this problem will chime in I'm sure those are just the first things that come to my mind
Brake Pressure Differential Valve Warning Lamp Switch, lights up if the brake fluid is low. Sometimes the valve gets out of adjustment, so the light on the dash comes on... and stays on.
The switch can also fail, it threads into this valve that some peeps call a proportioning valve.
C8AZ-2B264-A .. Brake Pressure Differential Valve Warning Lamp Switch =1968/79 F100/350, Bronco, Econoline & 1968/69 FoMoCo Passenger Cars.
Obsolete, available NOS & from auto parts stores.
Not a bad idea with the cord but I really want to fix it eventually. How did you sort yours out ? What did it end up being if you don’t mind ?
Yours certainly does not look like rust has ever been an issue under that hood F250C! Very nice condition.
But I would still maybe spray some penetrating lubricant on the linkage behind that bracket you show in your first pic. Just to see if it helps.
I don't know if they are metal-on-metal, or if there are bushings in the linkage that wear out. I would thing no to the bushings on a brake system, but I don't know and have not messed with one of these before.
Pedal pivot points can freeze up too when the plastic bushing wears out (which they do).
Boosters can fail, and that has been a subject lately with several different symptoms.
I suppose the multiple springs inside a master cylinder can rust and fail too. Never had that happen, but any spring can fail given time. And moisture does tend to hide inside a brake system. How does the fluid look? Ever changed it?
Sorry not much help.
Good luck.
Paul
Good luck.
Paul
