Led Quadbeam issue
Old Sep 6, 2019 | 02:49 AM
Mpj81's Avatar
Mpj81
Led Quadbeam issue
I just picked up a 17 f250 and my led Quadbeam headlights work on low beam and when put on my highbeams one of the low beams don't come on,any help appreciated in advance
Old Sep 6, 2019 | 05:39 AM
Poncho450's Avatar
Poncho450
All 4 of the bulbs have both high & low beam capability. It's not like 2 of the bulbs are high beam and 2 are low beam. Sounds like some kind of power interruption to the one light when the switch is flicked to high beam.
Old Sep 6, 2019 | 08:04 AM
GABAR's Avatar
GABAR
Are you saying that your vehicle has the "OEM" quad beam LED headlights?
Is your 2017 F250 a Lariat, or above trim level?
If so and I hate to tell you this but, the only way to fix this issue is to replace the entire headlight assembly or both if they have the same problem.
These are not serviceable like the halogen fixtures.
Old Sep 6, 2019 | 10:33 AM
mhoefer's Avatar
mhoefer
The LED lights are not the same, they don’t use H13 bulbs, low beam is the higher LED, when on high beam, the lower one comes on OTH the low beams. This seems like a fuse issue or a wiring fault. Depending on warranty coverage I would have dealer examine first. When they tell you what’s wrong, you can decide how to repair yourself. They will have to check in the IDS what’s working and not working.
Old Sep 6, 2019 | 11:10 AM
Mpj81's Avatar
Mpj81
I appreciate your replys,I guess I'll take it to the dealer or maybe pull the light and put a multi meter on the wires to it when the high beam is on see if it's getting juice
DeadFife
Apr 28, 2017 07:12 PM
Highjumper
Mar 24, 2017 01:12 PM
Skylaneman
Dec 8, 2012 12:17 PM
frank7mm
Nov 28, 2012 03:27 PM
Futuresweets-10
Mar 7, 2009 02:15 PM
