Sponsored by: Real Truck
9007 vs 9008 Headlights....
Old Mar 7, 2009 | 10:03 AM
Futuresweets-10's Avatar
Futuresweets-10
Ive been thinking about upgrading my headlights in my 01 to the 05+ lights, which means switching from 9007 to 9008 bulbs. I was also thinking about trying out a set of HID's to see if I like them since I can get them through one of my accounts for cheap. The issue is this, my supplier does not list 9008's so I assume they dont have them. I heard somewhere that H13 is interchangeable with 9008, and they do have H13. The 9007's are the only ones they carry that are listed as High/low and not just low beam. Can anyone help straighten all this out for me?
Old Mar 7, 2009 | 11:33 AM
DCSpecial's Avatar
DCSpecial
9008 is more commonly known and listed as a H13 bulb. So yes, you would use the H13.
Old Mar 7, 2009 | 12:52 PM
Futuresweets-10
The H13 is just a low beam kit, does that mean I wont have High beams at all, or does that mean the Highbeams will be the regular bulb?
Old Mar 7, 2009 | 01:55 PM
DCSpecial's Avatar
DCSpecial
Depending on the kit, it could just be Low beam.
I've seen H13s with the HID low and halogen high.
And I've also see the Bi-xenon H13s where both the High and Low beam are HID, or the capsule moves in the housing.
Old Mar 7, 2009 | 02:15 PM
ReAX's Avatar
ReAX
Usually if they don't state hi/low then they most likely only produce one light output. In most cases, the one brightness is more than sufficient. I would be wary of your supplier, 9007 and 9004 use the same plug, only switch a couple of the wires. The bulb is a little different, but the 9004/7 kits I've played with have either both groves or a flippable collar with the required groves on each side.
vtown00
Mar 7, 2014 12:40 PM
ExSKARsion
Ford Truck Parts for Sale
Nov 19, 2013 09:42 PM
teg2_nv
Aug 27, 2012 08:40 AM
Tampa250
Oct 21, 2011 05:25 PM
AndeyHall
Dec 4, 2010 03:57 PM
