I might get some summit shorty headers(SUM-G9036) for 86-95 5.8L. I will be paint them with high temp paint. It should fit my 84 even though they are for 86 and up b/c on autozone both the 84 and 86 take the same manifold and also on the cyberpartspro website, my 84 exhaust looks perfectly like the 85-86 302 or 351w with dual cats with the air tube but not the 84 picture.
so my questions:
I need some opinions on the summit headers(i'm in college)
I'll also go from the 2.25" pipe off the cat to a 2" borla muffler i found in the garage.
so what do you think of my setup?
I have the summit shorties on my truck. 5.0. They are ok.. Getting to the bolts tight is a real Pain in the butt. You can't even get a box wrench on them all of them. SO you have to use the open side of the wrench and you can;t get them tight. They start to strip first. I picked up a set of alen headed header bolts that helped, but If I was to buy headers again I would get better ones..
They a good if you are on a tight budget, but you will kick your self everytime the bolts loosen up and you have to replace the gasket yet again..
you would still want to go 2.5" or bigger....I have a 3" sysetem on my 302 and it runs great. But if its free thats great but if you get some money together you might wanna get a bigger one.
I have all winter to decide on weather to use the 2" borla or get another muffler.
I just read on the dynomax site that primary tube length:
Determines torque above or below the peak horsepower RPM point. Shorter tubes add torque above the peak RPM point and reduce torque below. Longer tubes add torque below the peak RPM point and reduce torque above it.
is that true?
does it have a large effect on the engine's proformance?
anyone know the peak hp/rpm point for a stock 84 351w?
