Rythmic thump after hard acceleration
Oct 17, 2019 | 06:13 PM
Is that nasty cover for the truck? If so, get the OEM aluminum unit. That's almost as bad as
@Tugly old steering wheel.
Oct 17, 2019 | 08:45 PM
Yup. That's what came off the truck. New aluminum cover is on its way.
Oct 18, 2019 | 05:18 AM
Oct 18, 2019 | 11:44 AM
Speaking of steering wheels, I got a squeak when I turn mine. Mostly hear when slowly turning. Any buddy know what that could be? WD don't help.
Oct 19, 2019 | 05:05 AM
@Tugly, lol at "like a hot girl with bad teeth". I'll have to remember that one. I decided to go with the factory aluminum cover.
Ford 8C3Z-4033-A 8C3Z-4033-A-COVER
@Bonanza35, boy that squeak could be anything. All I can say is start tearing into that steering column and grease everything that moves.
Oct 19, 2019 | 02:07 PM
I was trying not to have to tear it apart, at least taking the wheel off. But I guess that is exactly what I'll have to do. Need to get some tools. At least a puller. Probably have everything else.
Oct 21, 2019 | 01:08 PM
Figured out a way to use my transmission jack to lift the differential into the pumpkin.
Oct 21, 2019 | 01:32 PM
You must have decided on shim build I guess.
Oct 21, 2019 | 02:41 PM
I'm not sure what you mean Dan. Aren't shims the only thing one can use in a Sterling to adjust stuff?
Oct 21, 2019 | 09:28 PM
Quote:
Originally Posted by
FordTruckNoob
Those carrier bearings are on right? Is the Sterling shimmed on the outside of the bearing? Or on the inside like a D60?
Oct 21, 2019 | 09:31 PM
Quote:
Oh okay. Yeah they're shimmed on the outside.
Oct 22, 2019 | 05:48 AM
FordTruckNoob
Easy....well, easier than inside.
Oct 26, 2019 | 01:19 PM
She's fixed!!!! No more thump-twang.
Oct 26, 2019 | 03:05 PM
Oct 26, 2019 | 03:38 PM
Due in no small part to your loan of the clamshell puller Dan. It took me three iterations before the tooth contact pattern and backlash came out right.
