Rythmic thump after hard acceleration
Old Oct 14, 2019 | 08:40 PM
  #31
97-psd's Avatar
97-psd
Bummer. Good luck with the next one
Old Oct 14, 2019 | 11:16 PM
  #32
'88 E-350's Avatar
'88 E-350
Originally Posted by Bonanza35
Boy wouldn't think a TrueTrack would do that. Maybe it wasn't set up right from the beginning.
The broken gear probably has nothing to do with the TrueTrac.
Old Oct 15, 2019 | 02:04 PM
  #33
Bonanza35's Avatar
Bonanza35
I never put one in so wasn't thinking. You here so much good things about them you just wouldn't think this would be a problem. Install means everything.
Old Oct 15, 2019 | 02:20 PM
  #34
Dan V's Avatar
Dan V
Metallurgy means everything.
Old Oct 15, 2019 | 02:22 PM
  #35
Bonanza35's Avatar
Bonanza35
I know when we changed my son's gearing we used OEM gears. So a US made brand ring and pinion is what I would install.
Old Oct 15, 2019 | 02:35 PM
  #36
FordTruckNoob's Avatar
FordTruckNoob
Welp, the differential, pinion and pinion bearing cups are out of the pumpkin. Just waiting on parts to show up now. Here's another pic of carnage for your viewing pleasure.
Old Oct 15, 2019 | 02:38 PM
  #37
Bonanza35's Avatar
Bonanza35
Boy, that is bad. Did it just come apart or have you been pulling or racing? Another vote for the OEM parts.
Old Oct 15, 2019 | 07:34 PM
  #38
FordTruckNoob
Bonanza35, it was just regular acceleration onto the freeway. I do tow quite a bit though. I was unloaded at the time.
One thing that just crossed my mind is that I discovered my pinion had some axial play in it about a year ago. I tightened up the yoke nut and that seemed to cure it. Fast forward to today I noticed the teeth that broke on the ring gear broke towards the heels of the teeth. That indicates to me the pinion depth was too far away from the ring gear. I wonder if the shop that performed the previous install failed to seat the inner pinion bearing cup fully in the case. The cup then seated further into the case leading to axial play in the pinion. My tightening of the yoke nut then seated it all the way, leading to incorrect pinion depth.
One good bit of news is that all bearings are in good shape and not pitted. I'm replacing them anyway.
Old Oct 15, 2019 | 07:38 PM
  #39
slowsure's Avatar
slowsure
Just wow. Man that stinks!
I have considered putting in a True Trac but have balked at the fact that if not set correctly “this” could happen.
Hope you have the time to write up the install, from a purely selfish reason.
Either way good luck on getting the pumpkin back together.
Old Oct 16, 2019 | 08:30 AM
  #40
Dan V's Avatar
Dan V
Leonard, are you planning on doing the install yourself? Because if you are, I purchased a clamshell bearing puller when I set-up my D60, that I'd be happy to let you use.
Old Oct 16, 2019 | 09:17 AM
  #41
'88 E-350's Avatar
'88 E-350
My only two experiences with R&P breakage were with sandrails, but same basic concept. In both cases we were just cruising along when the noise started. It's very unlikely that they broke while cruising, it just went unnoticed at the moment that it happened.
Old Oct 16, 2019 | 11:16 AM
  #42
FordTruckNoob
Wow, that's very generous of you Dan. Thank you. I just wish I'd read your post before spending the last two hours cutting and chiseling bearing cones.
Old Oct 16, 2019 | 01:25 PM
  #43
Dan V's Avatar
Dan V
You will still need to set both the pinion depth and backlash....so, you either are using set-up bearings or on/off your new bearings.
Old Oct 16, 2019 | 02:40 PM
  #44
FordTruckNoob
Good point. I'll PM my phone number to you so we can set up a meeting. Thanks so much for letting me use your bearing puller!
Old Oct 17, 2019 | 03:41 PM
  #45
FordTruckNoob
Homebrew case spreader ready to go.
