Question about gasket kit
Old Sep 3, 2019 | 04:20 PM
Motohead911's Avatar
Motohead911
I have a question about Ford's Valve Grind Gasket Kit 5c3z-6079-g. Does anyone know what all is included in it. I am getting my parts list together to redo my head gasket.
Old Sep 3, 2019 | 04:46 PM
bismic's Avatar
bismic
From what I can recall, it includes (and there certainly may be more):
head gaskets
oil & EGR cooler gaskets
injector o-rings
fuel bowl o-rings and seals
high pressure oil rail fittings, o-rings & seals
dummy plug seals (old ones I believe)
turbo gaskets
rocker carrier gaskets
thermostat gasket
standpipes
I believe it also includes intake manifold gaskets, valve cover gaskets, and intake manifold donut o-ring (not 100% sure though)
It does not include exhaust manifold gaskets.
IIRC the dummy plug seals are just for the old style dummy plugs, so the updated dummy plugs would be wise in that case.
https://www.tascaparts.com/?year=&ma...&search_in=all
https://swampsmotorsports.com/produc...er-gasket-kit/
Note - the 5c3z-6079-g is for engines from 7/2004 up to January 2006
6C3Z-6079-E is for commonized engines (after early Jan 2006)
Old Sep 3, 2019 | 05:07 PM
TooManyToys.'s Avatar
TooManyToys.
Pics from Ford dealer sites, but no listing of all the parts. Maybe the right pics, maybe not.
Old Sep 3, 2019 | 05:25 PM
Motohead911
Ok here is question 2. Do you think it is worth it to get this kit and use OEM headgaskets, or piece it together and use Felpro headgasket. Either would be used with most likely KDD o-ringed head and ARP studs.
Old Sep 3, 2019 | 05:33 PM
bismic's Avatar
bismic
Or a third option is to get this kit, buy FelPro head gaskets, and don't use the OEM head gaskets (ie buy the Fel Pro gaskets separately). Afterall, the head bolts will get "discarded!
IMO piecing it together will be about what this kit costs - even if discarding the bolts and head gaskets
Old Sep 3, 2019 | 06:22 PM
TooManyToys.
I don’t know if monetary its worth it if you are going to discard both gaskets and the non sellable head bolts.
I was able to get the Felpro head gaskets from RockAuto on one of the several “wholesaler closeout” times for around $25 each. That, along with if you are not going to use the head bolts doesn’t make the kit that appealing to me.
Old Sep 3, 2019 | 07:00 PM
bismic's Avatar
bismic
From what I can "piece together" it is a wash (cost) buying the kit and discarding the bolts AND the OEM gaskets vs buying the individual gasket sets - around $500
Old Sep 3, 2019 | 07:18 PM
TooManyToys.
So you able to find a list of what’s included? That’d be helpful.
Old Sep 3, 2019 | 07:25 PM
bismic's Avatar
bismic
I edited my list above to be pretty darn close. Added links as well
The only conflicting information that I can see are on intake manifold gaskets ($12 each)
Old Sep 3, 2019 | 08:11 PM
TooManyToys.
Sorry, earlier blew right past your post.
Old Sep 3, 2019 | 09:29 PM
Motohead911
Thanks for the info, I decided to piece the parts together. I will be easier now that I have a much better idea of what it comes with. I really don't need all those extra bits and pieces.
Old Sep 3, 2019 | 09:40 PM
bismic's Avatar
bismic
Here is my stab at a pieced together list (attached) with Ford parts. $460 individually and $494 for the grind kit.
Then you need to add the updated dummy plugs (unless you have them already) and exhaust manifold gaskets IMO.
Old Sep 3, 2019 | 10:07 PM
TooManyToys.
It may be worth it Mark.
RockAuto doesn't seem to carry as much Motorcraft any longer for our trucks, so this is mostly Mahle, the supplier. Does not include the EGR hose/gaskets or the standpipes as they were of a poor grade.
Old Sep 3, 2019 | 10:14 PM
bismic's Avatar
bismic
Perhaps the standpipes aren't needed ..... if they have already been updated.
If the standpipes are included that is another $100 and the EGR kit is another $87.
Also looks like the Rock Auto intake gasket set already includes some injector o-rings. May not need the last like item (3C3Z09229-AA) that you included - depending on how deep into the injectors one would need to go.
Old Sep 3, 2019 | 10:15 PM
87crewdually's Avatar
87crewdually
