Driver door double pull
Old Sep 1, 2019 | 12:51 PM
983-over's Avatar
983-over
I have a ‘13 F150 Ecoboost. Several years ago it developed a problem that when I unlock the doors, the first pull on the handle the door is still locked. The second pull it opens.
This started while it was still in warranty and the dealer said he could fix it, but before the next time I was there it went back to operating correctly. Fast forward a couple of years, the warranty ran out and it came back.
Any ideas?
Old Sep 2, 2019 | 06:58 AM
06pghescape's Avatar
06pghescape
Same Issue
I have the same problem , went away and came back on its own.
Old Sep 2, 2019 | 09:02 AM
alloro's Avatar
alloro
It might be a case of the unlock actuator not pulling quite far enough. Have you tried lubricating the latch mechanism?
Old Sep 2, 2019 | 10:02 AM
06pghescape
I`ll try that , didn`t think it was any of the control modules because its only the drivers door.
Old Sep 9, 2019 | 12:56 PM
Cowboy-Carl's Avatar
Cowboy-Carl
I have a 2011 F-150 Lariat, my Passenger Door is doing the same thing. Some times it works fine the most of the time it does not. Wife says I am doing it so she has to get wet in the rain.
Old Sep 10, 2019 | 10:53 AM
06pghescape
Double Pull
I tried lubricating the actuator ; made no difference. I `m taking the truck to the dealer for some work , so i`ll ask them about the problem.
Old Sep 11, 2019 | 09:34 AM
alloro's Avatar
alloro
Originally Posted by 06pghescape
I tried lubricating the actuator; made no difference. I'm taking the truck to the dealer for some work, so I'll ask them about the problem.
Better bring that lube with you.
Old Sep 11, 2019 | 09:41 AM
06pghescape
Actually I just ask them to let me know what they thought is the problem is didn`t tell them to fix it. I`ve use this particular dealer because in the past they have done minor repairs without charging me.
Old Sep 13, 2019 | 12:15 PM
06pghescape
Update
Dealer tells me door handle needs replaced , didn`t quote me a price. I`m not sure that it`s that big of an issue for me.
Old Sep 24, 2019 | 09:41 AM
06pghescape
Exclamation Door handle update
Dealer quoted me .5 hr labor and $108.43 for part # 9L3Z5421813A Latch ( Labor is $110 an hour )
Old Sep 26, 2019 | 07:12 PM
meborder's Avatar
meborder
Any time I can get a car fixed for $100, I just write the check
Old Sep 26, 2019 | 08:06 PM
06pghescape
I will get it fixed because its just annoying and i`m afraid i will snap it off one of these days . Just had the left side exhaust manifold replaced it was $1070.29 Glad i have an extended warranty for that but it doesn`t cover the handle.
kylant
Jan 5, 2020 12:02 PM
Robert Hust
Jul 22, 2018 06:39 PM
79-ford-f150
2015 - 2020 F150
23
Feb 9, 2016 05:55 PM
n3up
1997 - 2003 F150
Apr 23, 2009 10:56 PM
slayerboy
1983 - 2012 Ranger & B-Series
Jul 7, 2002 05:17 PM
