Drifting
Old Sep 1, 2019 | 09:53 AM
Kerkoke's Avatar
Kerkoke
Drifting
I’m at wits end! New to me truck. 01 7.3. Started with new tires. Shop said needs ball joints and tie rods to align. Fine done! Drives worse! Jumps across road while driving. Replaced shocks track bar other tie rod and drag link and steering shock. Well everything is quiet now! But it still drifts. Does not come back to center after a turn. Stays turning! Is something hung up or binding? Every person has a different opinion and I can’t just keep throwing money at the “might be” the problem. Thanks
Old Sep 1, 2019 | 10:06 AM
seville009's Avatar
seville009
I had that happen to me after a tie rod was replaced. I took it back and they adjusted it. Can’t tell you exactly what they did though.
Old Sep 1, 2019 | 11:22 AM
FordTruckNoob's Avatar
FordTruckNoob
Adjust tie rod for more toe in.
Old Sep 1, 2019 | 11:32 AM
Kerkoke's Avatar
Kerkoke
Is that because it’s “the ford problem”. When you measure with a tape it’s right on. Is that a fix for it?
Old Sep 1, 2019 | 11:40 AM
FordTruckNoob
I'm not sure what you mean by that. What are you measuring with a tape measure? The length of the tie rod or the actual toe at the tires?
Old Sep 1, 2019 | 11:45 AM
pirate4x4_camo's Avatar
pirate4x4_camo
what are your alignment specs ?
how many miles on your new ball joints ?
what brand of ball joints did you have installed ?
Old Sep 1, 2019 | 11:59 AM
Kerkoke's Avatar
Kerkoke
Put in Moog. About 500 miles.
Old Sep 1, 2019 | 01:40 PM
z31freakify's Avatar
z31freakify
Maybe the aligment shop messed with the steering box adjusting nut and over did it making your steering box useless.
Old Sep 1, 2019 | 01:53 PM
pirate4x4_camo
need your current alignment specs or we are back to guessing
Old Sep 1, 2019 | 02:30 PM
brokestroke's Avatar
brokestroke
Check the u-joints.
Old Sep 1, 2019 | 04:21 PM
ebbnflow's Avatar
ebbnflow
It also sounds to me like your steering box has been tightened up too much. It's very sensitive to overtightening. Try backing it out a 1/4 turn and see if it makes an improvement in your return to center.
Old Sep 1, 2019 | 08:44 PM
Kerkoke's Avatar
Kerkoke
Update. Tonight after we did a tranny fluid change we decided to give the tie rod one twist for a little more toe in. It did seem to drive a little better! Going to try it for a week! Why wouldn’t the alignment shop catch that? Did they do a bad job? Can you screw it up at a shop? We even brought it back after. He said it was probably my gear box. Multiple mechanics said that was fine??
Old Sep 1, 2019 | 08:59 PM
pirate4x4_camo
because fords specs for alignment are very broad and most alignment techs are clueless how to tune a straight axle, they do what the computer tells them. you can make a Superdudy handle absolutely horrible snd still be in “in spec”. that is why i asked what yours is set at. give me your settings and i can make suggestions to make it handle like you want
Old Sep 1, 2019 | 09:09 PM
brokestroke
Bad axle u-joints.
Old Sep 1, 2019 | 09:54 PM
Kerkoke's Avatar
Kerkoke
Nope no one has touched the gear box. I thought about it but the 4 mechanics I had drive it said it was fine.
