Intake Manifold
Old Aug 29, 2019 | 02:46 PM
79Ford100's Avatar
79Ford100
Intake Manifold
Hi All,
I have an intake manifold with designation D7TE-AA. It came off a 79 302. The intake has a vacuum port where the brake booster vacuum line connects and several smaller vacuum lines came from (See attached image). This engine was modified because some of the vacuum lines were plugged. I would like a little more info on this intake to know where the vacuum lines go. Any help?
Thanks,
Dave
Old Aug 29, 2019 | 04:09 PM
440 sixpack's Avatar
440 sixpack
The vacuum lines can go wherever you want them to, and if you don't need them plug the holes. the only vacuum on an engine that's different from one port to the other is the timed " ported " vacuum on the carburator for your vacuum advance. other than that what goes where is meaningless.
Old Aug 29, 2019 | 04:15 PM
85e150's Avatar
85e150
There was a vacuum tree on some engines. Vacuum was used for some emissions stuff like EVAP, and in some vehicles for HVAC controls. Transmission modulator for C4/C6 maybe FMX equipped vehicles. Power brakes of course.
nintey4f150
Aug 1, 2012 10:31 AM
460
Feb 24, 2009 09:15 AM
johaner78
Jan 31, 2009 05:35 PM
sparky302
Apr 14, 2005 03:54 PM
jerrycarl
May 20, 2003 02:21 PM
