trick flow r series intake help
Old Aug 1, 2012 | 05:59 AM
nintey4f150's Avatar
nintey4f150
i was wondering who can help me out with some pics mayb of their 351 with a trickflow r series intake.. i would like to now how u ran all the vacuum lines to the intake and throttle body... i have the truck running but i wanna make sure its setup the best way
Old Aug 1, 2012 | 07:57 AM
Conanski's Avatar
Conanski
I don't have any pictures to show you but FWIW vacuum is vacuum so it really doesn't matter how or where everything is connected as long as there are no leaks. For example you could just connect single tubes to individual ports on the manifold but that could end up looking very messy, so another way to do it is with a vacuum tree like they have on the stock intake. But what I would do(will do whenever I get around to building my 5.8) is utilize a serprate vacuum manifold from another vehicle or from aftermarket suppliers, mount if back on the firewall and then have only one or maybe two connections to the intake at the rear where they're not that visible. The brake booster is the only other device that should go directly to the intake everythig else can go through the vacuum manifold. Many of the Ford cars utilize a plastic formed manifold like this and if you search the web you'll find suppliers for fancy anodozed aluminum and plastic versions as well.
Old Aug 1, 2012 | 10:31 AM
nintey4f150
yea that sounds good.. i just want it to look clean as possible even all the lines from egr n throttle body an all
dylansf23
13
Mar 21, 2016 07:21 PM
bruno2
Nov 13, 2011 08:28 AM
johaner78
Jan 31, 2009 05:35 PM
sparky302
Apr 14, 2005 03:54 PM
jerrycarl
May 20, 2003 02:21 PM
