Battery Saver Mode
Old Aug 29, 2019 | 10:06 AM
cmorningstar01's Avatar
cmorningstar01
Battery Saver Mode
I like to listen to my trucks radio with the engine not running and I will occasionally get a battery saver mode indicator on the radio and it will shut the radio off, My battery and alternator are both good and this is not a continuous problem just an intermittent problem, Anyone have any thoughts on this, why it happens and how to remedy it.
I found one You tube video that says disconnect the battery to let the computer reset.
Old Aug 29, 2019 | 10:28 AM
seventyseven250's Avatar
seventyseven250
Well, assuming it is letting you listen for a good long time, there isn't necessarily a problem to be solved here. If it's shutting off after only a couple of minutes, then that's not a good sign. Here's a few options.
You could reset the BMS, and maybe that'll help the truck re-learn the battery. This makes the most sense if the battery has been replaced recently.
You could charge the battery to 100% using an external charger and THEN listen to the radio for a while and see if you get more listening time. This is probably the lowest effort solution.
You could take the battery to get tested, because maybe it's not as "good" as you have assumed. Some people report weak batteries in brand new trucks, or defective brand new aftermarket batteries. There's no easy way to tell without testing.
Old Aug 29, 2019 | 10:38 AM
cmorningstar01
Sometimes I can listen to the radio for 15 minutes and then it shuts off without the battery saver indicator and I believe this is the standard built in safety feature, sometimes when I turn the ignition off and try to listen it goes right into battery saver mode.
Battery less than 1 year old and tests out fine and the condition did not start until apx 6-7 months after the battery was replaced
Can the BMS disable the rear window defroster? because this seemed to stop working about the same time now that I think of it, I originally thought it was a fuse or the switch but I checked all of the fuses and they are good and sometimes when I turn on the rear defroster it works for a few seconds(switch illuminates) and sometimes it doesn't
Old Aug 30, 2019 | 08:52 AM
Siberexpress's Avatar
Siberexpress
Have you unplugged your BMS? Also when the new battery was put in was the BMS Reset correctly by where the battery was put in or letting the truck sit for 8 hours and no extra power used like opening a door?
Ford Battery Management System or BMS
If you have a 5.0 or a 3.5 Ecoboost unplug the BMS and charge the battery up with a trickle charger overnight and then see what happens, the 6.2 does not have the BMS. I guess they didn't figure it was going to help on the gas mileage on it
I don't know if the 2011's did it but on my 2013 you can turn the radio on without the key being on also so it uses less juice.
As for the rear Defrost, sounds like a loose wire or connection, mine quit working completely right after I got the truck. I need to take it in before my Extended Warranty runs out and see if it and the sunroof are covered.
dirttoo
2009 - 2014 F150
15
Apr 18, 2017 09:11 AM
9rudy9
Electrical Systems/Wiring
Feb 4, 2016 10:16 AM
maytag906
2009 - 2014 F150
Feb 5, 2013 04:31 PM
CougarJohn
Aug 15, 2009 03:03 PM
HEC
May 17, 2003 08:28 AM
