door jamb paint failure
Old Apr 29, 2015 | 02:56 PM
Buck268's Avatar
Buck268
I noticed these spots while cleaning the door jams this spring, has anybody else had issues with paint rubbing or falling off of the inside of the door jambs? The doors do not rattle and they seem tight on their hinges I have never seen this before.
Old Apr 30, 2015 | 01:48 PM
meborder's Avatar
meborder
hummm ... interesting.
my door jambs are always "gravel brown" so I can't say as I've ever bothered looking.
if it were my truck, I'd probably just spray it with some primer and repaint it.
of course, if it WERE my truck, it would be covered with an inch of gravel dust, so I'd probably never notice it.
oooh for the days 10+ years ago when I didn't live on gravel ...
Old May 1, 2015 | 11:15 AM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by Buck268
I noticed these spots while cleaning the door jams this spring, has anybody else had issues with paint rubbing or falling off of the inside of the door jambs? The doors do not rattle and they seem tight on their hinges I have never seen this before...
Hi Buck268,
You might want to have your dealer take a peek to see what could be causing the paint to chip off like that. What's your truck's model year and mileage?
Crystal
Old May 1, 2015 | 05:13 PM
Buck268's Avatar
Buck268
Originally Posted by FordService
Hi Buck268,
Crystal
2011 65,000 miles. Well outside warranty.
Old May 2, 2015 | 09:32 PM
fordman19762003's Avatar
fordman19762003
looks like the paint is popping off right where the gasket touches the door when closed. Also looks like you have some rust starting in the bare spots and along the seam at the bottom. My guess is that some grit got in between the gasket and the door and wore through the paint enough for corrosion to set in.
Old May 2, 2015 | 11:08 PM
PinMd's Avatar
PinMd
Sure looks like a poor prep situation, paint didn't stick to the primer well enough.
Gonna ask some dumb questions. Has the door had any body/paint repairs done to it? Are you the original owner?
As previously stated, I'd pull the trim panel, scuff it, and prime and paint it. While you have the trim panel off you can inspect for previous repairs and get a look at the condition of the inside of the door, make sure there's no corrosion starting.
Also, your correct, I doubt Ford will do anything for you, but if you bought it new, your dealer may take care of it as a customer service deal.
Old May 4, 2015 | 09:04 AM
FordService
Official Ford Rep
Thanks for replying, Buck268. If you decide to get your dealership involved, let me know and I'll see what I can do to assist from my neck of the woods.
Crystal
Old Aug 31, 2019 | 06:44 PM
JockeyJames's Avatar
JockeyJames
Trailering
Did this get resolved? I am having the same issue with my 2016 f250. It's rusting under the paint. The steel is all oxidized and rusting causing the paint to lift. I have 44k miles and of course outside my warranty.
Driver door
Passenger rear door
bhmayor
Paint & Bodywork
Apr 27, 2017 09:00 AM
Redeyeracing
Aug 13, 2016 11:53 AM
berry1234
20
Oct 12, 2009 11:08 AM
Tylus
2004 - 2008 F150
22
Apr 13, 2007 07:06 PM
1olddog2
Aug 9, 2004 12:25 PM
