Transmission flush
Old Oct 7, 2003 | 01:24 PM
beartracks's Avatar
beartracks
Transmission flush
I'm going to flush my C-6 by disconnecting the cooling line at the radiator and running the engine while I pour new oil in the dip stick tube. Anyone done this? Wondering if I'll make a mess. How much pressure and volume to expect.
Old Oct 8, 2003 | 12:21 AM
BlueOvalFitter's Avatar
BlueOvalFitter
I pulled my return line at the cooler and pumped almost 5 quarts in less then 25 seconds.I dont think you are going to be able to keep up with that rate if your pouring it in.
Old Oct 8, 2003 | 05:00 AM
Torque1st's Avatar
Torque1st
Posting Legend
I have talked about changing tranny fluid in this manner in several forums. You run the cooling line into a bucket until you get bubbles. Add a couple of more quarts of fluid to flush and watch for bubbles again. Button the system back up WITH A FILTER INSTALLED in the cooling line! Then fill it back up.
Old Oct 8, 2003 | 04:47 PM
gdavis2265's Avatar
gdavis2265
yea, I use approx 3 empty milk jugs- fill one half up and stop truck, pour in two quarts, keep doing it untill all are dilled- Worked great on my grand cherokee.
Old Oct 8, 2003 | 06:35 PM
Torque1st's Avatar
Torque1st
Posting Legend
With my method you get a complete flush and only waste two quarts of fluid.
comsupany
Mar 24, 2016 05:06 AM
"Phatman"
Aug 3, 2015 07:26 AM
plummer
1997 - 2003 F150
Mar 12, 2015 09:03 PM
69ford99
2004 - 2008 F150
Sep 5, 2009 09:47 PM
ronk1969
Jul 19, 2006 09:36 PM
