CB Antennas
Old Aug 28, 2019 | 12:29 PM
Rick Cargo's Avatar
Rick Cargo
CB Antennas
I was working on my truck so that I can install my CB and realized that my magnetic mounted Wilson 500 CB antenna won't stick due to the body panels being aluminum. Have any of you come up with a solution to using a magnet mounted roof CB antenna?
Old Aug 28, 2019 | 12:56 PM
eaglelope's Avatar
eaglelope
7th Gear
Check this thread : https://www.ford-trucks.com/forums/1...a-bracket.html
and this https://www.larsonelectronics.com/pr...d-brake-lights
Old Aug 28, 2019 | 06:56 PM
Straightgrain's Avatar
Straightgrain
Temp solution
I needed my mag mount for hunting season, so I taped the mag mount to the top of the bed's sidewall behind the RR passenger door.
Black guerrilla tape x 10 days, still solid.
Old Aug 28, 2019 | 07:16 PM
JeepPuller's Avatar
JeepPuller
I pulled the rare earth magnets out of a bunch of old hard drives and assembled them into a circle. Then siliconed them to the underside of the roof via the third brake light access. I got the tip from here or YouTube. I do not remember which.
Old Aug 28, 2019 | 07:28 PM
jade97's Avatar
jade97
On my 2011 F150, I used a stake pocket mount and a Firestik, running the coax through the cab vent (with a drip loop). VSWR was not perfect, but acceptable.
Old Aug 28, 2019 | 07:41 PM
ZAR2USA's Avatar
ZAR2USA
Or you can purchase 3M magnet sleeve with adhesive.
I use either my steel toolbox for magnet mount or my larsonelectronics 3rd brake light mount. The aluminum bracket have a sheet of steel secured to it that allows for the magnet to secure.
Old Aug 28, 2019 | 08:50 PM
Rick Cargo's Avatar
Rick Cargo
Thanks Guys for your responses!
Old Aug 28, 2019 | 10:34 PM
ZAR2USA's Avatar
ZAR2USA
Oh and no wind noise, perfect fit with all needed hardware and gasket. I own two of their mounts, top quality, fit & finish. I interchange hardware with magnets on them as needed and store it away out of the elements when needed. Super low profile and nearly unnoticeable unless pointed out.
Old Aug 30, 2019 | 09:28 AM
delorenzomp's Avatar
delorenzomp
I used a Breedlove Stake Pocket mount.
Old Aug 30, 2019 | 01:08 PM
TXSD6.2's Avatar
TXSD6.2
I also used a Breedlove Stake Pocket mount on my 2019. Those mounts are awesome.
Old Aug 30, 2019 | 11:51 PM
Jimmy Pet's Avatar
Jimmy Pet
Is it not possible to clamp to the horizontal mirror arms?
I know its an older truck, but thats how I have had mine in my 2004 for over 10 years.
I looked at the new ones and its still a twin strut design.
Should be pretty easy to fabricate a non-marring clamp.
Samorkand
Jul 25, 2012 04:41 PM
bbshriver
Aug 11, 2011 06:33 PM
Skullonarm
Dec 3, 2008 09:15 PM
Hotshoe
Mar 28, 2004 09:24 PM
