'07 4.6 running lean
Old Aug 28, 2019 | 08:43 AM
stephen.osborne1's Avatar
stephen.osborne1
My daughter's '07 SCAB 4x4 with the 4.6 keeps throwing codes for lean bank 1 and 2. We've replaced the MAF sensor, tried a different throttle body, replaced the intake manifold gaskets (for coolant leaks) as well as several COPs and all the plugs. The fuel pressure at the injectors seems fine (my buddy tested them with his SnapOn tool). We also haven't found any vacuum leaks. The only other thing I can think of might be O2 sensors. Any other ideas before I throw more money at it? I tried searching but didn't find my exact issue.
Old Aug 28, 2019 | 01:54 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
What is the fuel pressure according to your buddy's SnapOn tool?
Old Aug 28, 2019 | 08:52 PM
projectSHO89's Avatar
projectSHO89
Did you check for freeze frame data so you can see what the operating conditions are when the code is set?
Old Aug 30, 2019 | 01:53 PM
Bluegrass 7's Avatar
Bluegrass 7
The codes are based on long term fuel table shifts.
Since you have codes for both banks, there is unaccounted for air the Ox sensors are detecting both banks.
It's not the Ox sensor.
That means the issue is common to all cylinders.
Intake tract vacuum leak, lean fuel.
You just have not found the source, look more and at any hoses or fittings that have access to the intake tract.
Good luck.
Old Aug 31, 2019 | 09:20 AM
redfishtd's Avatar
redfishtd
build a you tube smoke machine . I did and it worked great found a leak mech had given up on .Intermittent surging at idle is another symptom of vac leak .One friend found his at gasket on fuel tank for fuel pump .
Old Aug 31, 2019 | 10:22 AM
alloro's Avatar
alloro
"seems fine" or is fine...what was the fuel PSI reading?
Old Sep 2, 2019 | 04:42 PM
stephen.osborne1
I don't recall what the actual pressure was, but it showed each individual injector had pressure within specification, according to the Ford software.
I'll keep looking for vacuum leaks... This seems like the most likely culprit.
5.4L to Freedom
May 27, 2010 11:35 PM
tedalmeida
1997 - 2003 F150
Oct 26, 2009 06:41 PM
Rcmgiasson
1997 - 2003 F150
Nov 26, 2007 09:31 PM
ken9009
Modular V8 (4.6L, 5.4L)
Jul 24, 2004 10:21 PM
belly boat
Sep 23, 2003 09:48 PM
