NSS reset on Excursion
Old Sep 4, 2019 | 08:42 PM
Restlesswildman's Avatar
Restlesswildman
If you are talking about the PRNDL needle on the gauge cluster, there is an adjustment under the kick panel by the steering column!
Old Sep 4, 2019 | 10:46 PM
projectSHO89's Avatar
projectSHO89
That's only applicable AFTER everything else is working correctly but the pointer is off. Otherwise, leave it alone.
Old Sep 9, 2019 | 05:33 PM
Swaybar1's Avatar
Swaybar1
Checking back
The NSS is in neutral. When the vehicle is put in reverse the reverse lights come on. The vehicle will crank fine in P, & N and not in any other loc.(D,R,1, or 2). The batteries are charged and have been checked. Both batteries have been disconnected for longer than 30 minutes. No errors were detected with the OBD2 (innova 3030).
The vehicle will crank crank but not start. The fuel filter has been replaced (was black) fuel was in the bowl. A whisper of starter fluid was blown into the intake and it started briefly and then stopped.
Old Sep 9, 2019 | 09:09 PM
projectSHO89
The TRS is fine, leave it alone going forward.
Is this a gas or diesel?
What does the THEFT light do when you switch from OFF to RUN (not START).
Old Sep 10, 2019 | 06:47 AM
Swaybar1's Avatar
Swaybar1
This is a 2003 EXC w/7.3L.
The theft light goes out I believe.
Old Sep 10, 2019 | 08:00 AM
projectSHO89
You "believe" or you "know"?
Old Sep 10, 2019 | 05:46 PM
Swaybar1's Avatar
Swaybar1
It goes out. Here is a video
Old Sep 10, 2019 | 06:17 PM
01__Excursion's Avatar
01__Excursion
Your theft light is normal.
I can only be minimal help as I have a 2001, but it's still a 7.3.
It's probably a good time to ask for more symptomology. When was the vehicle last running, was ANYTHING done to it just prior to it not firing off? Like any mods, battery replacements, fuses touched, anything?
How did the shift linkage come off, was it from a bad bushing?
Has the glow plug module and relays been tested?
Have you checked the plug pigtails for the EOT (engine oil temp sensor), ICP (injection control pressure) sensor, IPR (injection pressure regulator).
The most important, and probably the first place to start:
You're not getting a response from your Tach when cranking, have you tried a new camshaft position sensor? on the 2001 the tachometer will move when cranking.
Old Sep 10, 2019 | 09:01 PM
projectSHO89
Okay, starter circuit is good, PATS is happy. You need a diesel guy now (which I am not).
Old Sep 11, 2019 | 08:23 AM
Swaybar1's Avatar
Swaybar1
I will be changing the cam shaft sensor this morning.
Before this happened (and I mean right before the linkage came off) the vehicle had been driving fine. It was driven to a location, put into park(left running) and then when she returned to it minutes later it wouldn't go out of park because the linkage under the vehicle had become disconnected. I TURNED THE VEHICLE OFF.😩
At first I thought it was the cable in the column so I took apart the housing around the column (also removing the key mechanism), and the fuse block to get a better look there. That cable was off also. After putting that back together and realizing that didn't help I looked below and saw the linkage. Since then the vehicle hasn't started.
Old Sep 11, 2019 | 11:14 AM
Swaybar1's Avatar
Swaybar1
I changed out the camshaft sensor this morning but the vehicle will still only crank but not start.
Old Sep 11, 2019 | 07:14 PM
01__Excursion
You mentioned removing the fuse block to have a better look at the interior shift cable, might be a good place to return to as there is possibly a poor connection after disturbing it.
Old Sep 13, 2019 | 10:18 AM
  #28
Swaybar1's Avatar
Swaybar1
Yes, I thought too, and have returned to it more than once also checking all fuses (just the bus type) and even found one out in the #2 slot but nothing else...
Old Sep 21, 2019 | 04:33 PM
  #29
Swaybar1's Avatar
Swaybar1
Update
The TRS has been changed. The error results were prior to this change.
The cam sensor has been changed.
The fuel filter has been changed.
The batteries are charged and have been checked but still it will turn over but not start. I'd take it to a mechanic if I could get it to one and they could look at it within two weeks.
Old Oct 9, 2019 | 06:27 PM
  #30
Swaybar1's Avatar
Swaybar1
I changed the transceiver and no luck. My next options are change the starter, and batteries....."is anybody out there"
Maybe some 7.3L's are never meant to restart
