Drive belt question
Old Aug 27, 2019 | 07:37 AM
dhart99's Avatar
dhart99
Drive belt question
I just recently got a 1989 f 250 light duty with a 4.9 5 speed, my question is about the serp belt and water pump. The truck is factory equipped with a/c but a previous owner took the comp off and changed the serpentine belt to one for a belt for a truck without a/c. The question I have is the a/c belt for a/c and the one for non- a/c turn the water pump in different directions. When I looked up a water pump for this truck it didn't specify with or with out a/c. Does this pump work in both directions on an 89 4.9l ?????
Old Aug 27, 2019 | 10:48 AM
jas88's Avatar
jas88
I really doubt Ford would go to the trouble and expense of having 2 different water pumps for a/c and non-a/c, but I am just guessing. That doesn't mean the PO routed the belt correctly, tho. You really need to see the diagram for routing the belt on a non-a/c truck to be sure.
Update: I checked RockAuto and there is no callout for a/c or non-a/c applications on the water pump, so I am confident in saying that the water pump turns the same direction in both applications. If you are concerned, you need to confirm your belt is routed correctly.
Old Aug 27, 2019 | 01:36 PM
dhart99's Avatar
dhart99
I figured out the po put the belt on wrong thanks for responding
Old Aug 27, 2019 | 01:58 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Without a/c would have used an idler pulley in place of the compressor.
Old Aug 27, 2019 | 03:03 PM
mark1986F150's Avatar
mark1986F150
The serpentine belt can only turn the water pump in one direction, although it's not immediately obvious when looking at the belt routing diagrams
zigzag02
Aug 24, 2018 04:02 PM
JamesHajek
24
Mar 12, 2012 06:55 PM
kuskye25
Mar 13, 2008 07:02 PM
88_150
Feb 11, 2003 09:25 PM
