window gaskets
Old Aug 25, 2019 | 01:42 PM
bobcat10_4's Avatar
bobcat10_4
window gaskets
Hello everyone, I am looking for some gaskets for my 86, F250 XLT Lariat king cab 4x4 diesel. The gaskets in particular are the sealing gaskets between the side windows behind the doors and the glass. I can not seem to find them anywhere and I now get to fix the rust at the bottom parts of the cab under these windows. Any thoughts? Thanks, Bobcat
Old Aug 25, 2019 | 02:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bobcat10_4
Hello everyone, I am looking for some gaskets for my 86, F250 XLT Lariat king cab 4x4 diesel. The gaskets in particular are the sealing gaskets between the side windows behind the doors and the glass. I can not seem to find them anywhere.
Pic: 21452? If so, they're reproduced, but are referred to by different names
Ford: Belt Weatherstrips // Repro parts sellers: Anti-Rattlers // Auto glass shops: Cat Whiskers
1980/86 F100/350 & Bronco: There are four different belt weatherstrips:
EOTZ-1021452-A Right Outer & EOTZ-1021453-A Left Outer.
Not shown in pic: EOTZ-1021456-A Right Inner & EOTZ-1021457-A Left Inner.
Old Aug 25, 2019 | 02:12 PM
Rembrant's Avatar
Rembrant
I just bought a complete kit (Fairchild brand) on Ebay, and so far everything it fitting nicely. I don't have every piece installed yet, but did the vent windows this week, and the one that attaches to the interior door panel. This kit has everything in it, even a rear window seal.
https://www.ebay.com/itm/Fairchild-I...72.m2749.l2649
They also have a small kit as well.
https://www.ebay.com/itm/1980-86-For...QAAOSwIdtae349
Old Aug 25, 2019 | 02:49 PM
FuzzFace2's Avatar
FuzzFace2
Guys I think he is talking about the side glass to the rear of the doors on the extended cab trucks.
Would they use the same type of rubber seal as the back glass? If so and still soft he could pull the glass & seal to fix & paint the rust and pop the glass back in pretty easily.
So Bill do you have a picture of this side rear glass & seal?
Dave ----
Old Aug 25, 2019 | 03:17 PM
bobcat10_4's Avatar
bobcat10_4
window gaskets
Yes, guys I am talking about the windows behind the doors on an extended cab truck. These windows don't open.
Old Aug 25, 2019 | 03:20 PM
Franklin2's Avatar
Franklin2
They sell rubber gaskets in bulk lengths. Here's some on Amazon. Not sure if you could get it bent around the corners though.
Amazon Amazon
Old Aug 25, 2019 | 03:22 PM
NumberDummy
Upper pic: Where is the weatherstrip? No see um.
Old Aug 25, 2019 | 03:38 PM
bobcat10_4's Avatar
bobcat10_4
Window gaskets
Those are the windows and I can see the number that Looks like the gasket\ seal #. I will try to look it up. Thanks
Old Aug 25, 2019 | 08:58 PM
FuzzFace2's Avatar
FuzzFace2
What number are you seeing?
As Bill said I dont see anything pointing to a gasket so thinking they are glued in like all the new stuff.
Dave ----
Old Aug 25, 2019 | 09:14 PM
DarkOverCast's Avatar
DarkOverCast
I've been looking for a kit to redo mine along with a set of good used glass so I can tint to keep the sun out. Thanks for the links and review!
Old Aug 26, 2019 | 12:01 AM
NumberDummy
Those are the windows and I can see the number that Looks like the gasket/seal #.
Lotsa luck!
You see the number? Where...since there isn't one for the gasket/seal only??
EOTZ-1329700-B Right & EOTZ-1329701-B Left .. Super Cab Quarter Window Assy's - Includes weatherstrip / NAGS number: Q6071 right & Q6072 left / Obsolete
1980/91 F150/350.
Old Aug 27, 2019 | 02:21 PM
bobcat10_4's Avatar
bobcat10_4
Window gaskets
Dave ----
#29700, I believe
Old Aug 27, 2019 | 04:59 PM
NumberDummy
# 29700 .. I believe
This is the glass & frame assembly, the weatherstrip is made as part of it. See post #11.
Old Aug 27, 2019 | 05:14 PM
bobcat10_4's Avatar
bobcat10_4
Is the weather stripping still available or do I need t go t a site such as Steele Rubber products?
Old Aug 27, 2019 | 06:11 PM
NumberDummy
You cannot buy the weatherstrip, as it was only supplied with the 29700/29701 glass/frame assy.
Look at the pic in post #11. Do you see a separate weatherstrip? No, you don't...because...there was no such thing.
1996_5.8
17
Sep 17, 2023 06:55 PM
NashvegasMatt
23
Mar 17, 2018 02:24 PM
Lindemanlax
Jun 7, 2014 02:06 AM
SIXTFOR
May 28, 2014 11:05 AM
Ak Ford Man
Apr 14, 2011 12:18 PM
